Directed to Illinois/Chicago land area.(Other people can help to)
Old Aug 5, 2006 | 10:48 PM
Civic Hybrid's Avatar
Default Directed to Illinois/Chicago land area.(Other people can help to)
Alrite I failed emissions testing today. THE DETAILS: I have a 2000 civic hatch and a b16a which is obd1. The place failed me because they couldn't get an obd scan because Im obd1. I have no idea on how to get around this without an obd2. The ecu is a stock p30. Has anyone had this problem and how did they get around it?
Old Aug 6, 2006 | 08:03 AM
Default Re: Directed to Illinois/Chicago land area.(Other people can help to) (Civic Hybrid)
Anyone..........anyone out there.
Old Aug 6, 2006 | 12:25 PM
boostd92's Avatar
Register it down south. There are no emissions tests about 30 miles south of Champaign. They don't even ask you to prove your address... you just have to have an address to give them. Find somebody in a local club who doesn't mind emailing you when you get mail from the DMV - cause it will go there.
Old Aug 6, 2006 | 06:07 PM
K-EG's Avatar
why dont you buy a stock b16 ecu and a obd2-obd1 harness.should work out
Old Aug 6, 2006 | 09:31 PM
Relic1's Avatar
if you have a 00 hatch, just pick up an OBD2b ECU from the SI, rig up the secondary O2 sensor with a simulator and jumper the crank fluctuation sensor and go for the test.
when you're done put back in your OBD2-OBD1 harness and the P30 and no more worries.
Old Aug 6, 2006 | 10:45 PM
Default Re: (Relic1)
well i guess thats a good start for some options. Any other ideas are welcome.
Old Aug 7, 2006 | 12:35 PM
Relic1's Avatar
sorry for throwing another response in here...
In IL, a 2000 car must have an OBD2 ECU. There is no way around that.
the good news, the actual testing is really easy, they simply make sure there are no codes set and pressure test your gas cap and you drive out. 5 minutes tops.
OBD1 cars are a pain to have tested. At least until feb 1.
Old Aug 8, 2006 | 12:19 PM
The thing is I have no idea on how to rig up all these sensors.
Old Aug 8, 2006 | 02:31 PM
Relic1's Avatar
hit me up, we can work something out to get you past the emissions stuff.
Old Aug 8, 2006 | 10:53 PM
alrite i'll pm you tomorrow we can work something out.
93egboosted
10
Jul 22, 2008 12:58 PM
Civic Hybrid
Mar 25, 2008 11:26 AM
civicobd1toobd2
May 10, 2006 02:52 PM
B18C_EJ8
Mar 6, 2006 10:41 AM
GRAVEDIGGER
12
Aug 15, 2003 11:59 AM
