LS Swap- CODE 14! HELP!!!
I just swapped a b18b into my 95 civic. Unfortunately, I'm throwing a code 14 (iacv). I sprayed carb cleaner on it and it didn't work. I then replaced it with a different b18b iac valve and im still getting the same CEL. I have reset the ecu, checked for vaccum leaks, im gasket leaks, pulled the ecu and ecu backup fuses etc. Any other ideas??? Im stuck and in need of help!
i know nothing is wrong with the harness cuz i just pulled it off the other engine, put it on this one and put it all in the car. the wiring harness was fine on the d-series but ill double check. any other ideas?
dodgeman711
Jun 24, 2010 06:04 AM
efsedan
Jun 26, 2007 05:56 PM
dad0c402
May 5, 2007 08:06 PM
jdoggmr2
Jun 25, 2006 03:44 PM
