axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas!
Old Aug 5, 2006 | 06:37 PM
Ideal's Avatar
Default axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas!
Here are some pics of my issue, basically no matter what i could not get it off from underneath the car, so i pulled out the entire intermediate shaft to try and get an idea of whats going on, need some help guys! thanks
Old Aug 5, 2006 | 06:59 PM
92hondalude's Avatar
Default Re: axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas! (Ideal)
beat that **** with a hammer
Old Aug 6, 2006 | 12:56 AM
Ideal's Avatar
Default Re: axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas! (92hondalude)
lol can you see the dents I left in that thing?
Old Aug 6, 2006 | 04:48 AM
have you hit it with a hammer then turn it a little then hit it at a new spot?
Old Aug 6, 2006 | 06:24 AM
Speedra500's Avatar
haha, you cant pull on the axle because, as you can see it will slide out of the cv-joint, like what happened there, it's not broken, anyhow try also putting some penetrating oil in there and hammer on intermediate shaft a little to loosen things up, also it is imperative that the intermediate shaft is mounted or being held securely while you are hammering on the axle, the initial shock is what will break it loose, if it slides around at all while you are hammering on the axle it won't come out
Old Aug 6, 2006 | 07:28 AM
NAiL05's Avatar
Yep what he said above me. It needs to be held still to be able to knock it out if not your just wastin your energy. I got me a lil chisel and tapped all around it too loosen it up and it just came out. Did it with my friends axle recently had the same problem as you too.
Old Aug 6, 2006 | 08:06 AM
tacticalcustoms's Avatar
ya crowbar and a hammer.. works great... the vibrations that the hammer send through the metal will actually help break it loose.. :D
Old Aug 6, 2006 | 08:09 AM
Ideal's Avatar
Default Re: axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas! (tacticalcustoms)
well I reattached it and still nothing, chiselled all around it hammered it, still nothing, this axle had been bad and knocking for a good amount of time, its probably just stuck good, I had a dream last night that I attached a rope to it and used 2 cars to pull it out lol, im actually thinking that may be a good idea
Old Aug 6, 2006 | 08:29 AM
SKDRCR's Avatar
did ypu try putting the imtermediate shaft in a vise grip to hold it still
while you hammered the **** out of the axle?
Old Aug 6, 2006 | 08:40 AM
Eddiebx's Avatar
why dont u just stick a pry bar between the inboard joint and the intermediate shaft, then pry it and hit it with a hammer.
you will generate far more force on it with a pry bar and a hammer, than hammering directly on the joint.
Old Aug 6, 2006 | 01:41 PM
jakeiscool's Avatar
Banned
Default Re: (Eddiebx)
you need an impact with a chisel on it. That thing needs to be "shocked" to get it out.
Old Aug 6, 2006 | 01:51 PM
.BigSexy's Avatar
most hood white kid
Default Re: axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas! (Speedra500)
haha...buy a new halfshaft. damn man, that sucks. WTF did u do?
Old Aug 6, 2006 | 01:56 PM
Slatelude's Avatar
Default Re: (JakeIsCool)
Here is how I've always got it off (red arrows showing where to pry, and yellow thing representing a large screwdriver/prybar, then just give it a good whack)
Good luck (yes, very helpful if its mounted in the car, i would imagine)
K
Old Aug 6, 2006 | 03:11 PM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ideal &raquo;</TD></TR><TR><TD CLASS="quote">I had a dream last night that I attached a rope to it and used 2 cars to pull it out lol, im actually thinking that may be a good idea</TD></TR></TABLE>
don't laugh too hard at that idea....I attached a rope to my old axle and pulled on it with my buddy's taurus.....bitch popped right out!!
Old Aug 6, 2006 | 03:51 PM
TurboBA8's Avatar
Default Re: (Slatelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slatelude &raquo;</TD></TR><TR><TD CLASS="quote">Here is how I've always got it off (red arrows showing where to pry, and yellow thing representing a large screwdriver/prybar, then just give it a good whack)
K</TD></TR></TABLE>
i used this method as well. it worked great!
Old Aug 6, 2006 | 03:53 PM
Default Re: (TurboBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboBA8 &raquo;</TD></TR><TR><TD CLASS="quote">i used this method as well. it worked great!</TD></TR></TABLE>
thats basically what honda says to take it out anyways.. I've used this idea also...
Old Aug 7, 2006 | 01:38 PM
Ideal's Avatar
hey guys, so i finally got it off with a BFH and a vice, the ring on the end of it, i dont take that off right?
Old Aug 7, 2006 | 02:57 PM
SKDRCR's Avatar
Default Re: (Ideal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ideal &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, so i finally got it off with a BFH and a vice, the ring on the end of it, i dont take that off right?</TD></TR></TABLE>
nope, that's the snap ring to keep it in place
EGPrelude
Jun 17, 2008 07:46 AM
Hoppa
Dec 5, 2006 08:51 AM
racingcrx
Jul 25, 2006 09:14 PM
huepowered
Mar 27, 2006 12:33 PM
SoOHiGH
18
Jul 6, 2005 07:48 PM
