need a write up for itr 5lug on INTEGRA..
Old Aug 5, 2006 | 05:35 PM
4play4dr's Avatar
Default need a write up for itr 5lug on INTEGRA..
ive searched and only found the onw from jdmvtec.com..and thats for an EG..wanna see one for a DC..help a brotha out!
Old Aug 5, 2006 | 10:04 PM
SuzukaBlueAP2's Avatar
Default Re: need a write up for itr 5lug on INTEGRA.. (4play4dr)
A write up on what? swapping out the 4 lug for ITR 5 lug?
P.S. It should be the same from a Civic as it is for Integra. They are the same platform.
Old Aug 8, 2006 | 01:30 AM
4play4dr's Avatar
Default Re: need a write up for itr 5lug on INTEGRA.. (SuzukaBlueAP2)
just wanna see the exacts..cuz people do civics that have drum brakes in the rear..the fronts i can understand..just need a write up for the front..and anything else with the brake lines or something
Old Aug 8, 2006 | 11:29 PM
4play4dr's Avatar
anything??
Old Aug 9, 2006 | 01:07 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You do realize that the suspension setup of an EG is the exact same as a DC, the swap would be the same...
Old Aug 9, 2006 | 04:46 PM
4play4dr's Avatar
Default Re: need a write up for itr 5lug on INTEGRA.. (JDM_Ej)
yea..but i thought that the lines or anything small would be different..ive heard something about the brake lines having to be moved around or something..something with the lines..but i guess ill just attempt to do it and see how it goes
Old Aug 9, 2006 | 08:02 PM
gldndrgn14's Avatar
if you need that much help, than sorry to say, you shouldnt be doing this. its straight forward.
Old Aug 10, 2006 | 05:39 PM
4play4dr's Avatar
Default Re: need a write up for itr 5lug on INTEGRA.. (gldndrgn14)
yea..ima just do it..i was hoping for a more detailed write than the ones ive found..but i can work wit it..thanks guyz
mitch6
Suspension & Brakes
Apr 11, 2011 04:13 PM
1Bar GSR
Apr 24, 2006 05:59 PM
DexterThEG
Sep 13, 2004 09:39 PM
S2K2S
24
Apr 1, 2004 09:39 PM
Captn. Save A Hoe
Jan 10, 2003 11:59 AM
