Need help. 5 lug ITR/CTR suspension problem.
Old Jan 9, 2003 | 06:10 PM
Captn. Save A Hoe's Avatar
Default Need help. 5 lug ITR/CTR suspension problem.
Im having my uncle send me a swap from japan. What exactly is included in the swap. So i can tell him exactly what i need. thanx in advance
chris
IMPORT smote
Old Jan 9, 2003 | 06:20 PM
YumVTEC's Avatar
Default Re: Need help. 5 lug ITR/CTR suspension problem. (teampr1ckcivic)
front:
- knuckles, hubs, rotors, calipers, brake pads, misc. nuts bolts (if you're bolting onto an EG or integra then get upper and lower control arms as well 'cause the ITR ones have stiffer bushings)
rear:
- trailing arm assemblies with spindles, rotors, calipers, brake pads, e-brake cables (get ITR rear LCA's if you have an EG or integra, then you'll be able to use ITR OEM and aftermarket suspension )
Getting the brake lines with all this would be great too...
[Modified by YumVTEC, 3:20 AM 1/10/2003]
Old Jan 9, 2003 | 06:25 PM
Default Re: Need help. 5 lug ITR/CTR suspension problem. (YumVTEC)
Thank you sir...you have been a great help..
ill jus get some sort stainless steel lines
Old Jan 9, 2003 | 06:56 PM
10K2HVN's Avatar
JDM ITR's also need 36mm outer and 32mm inner axles..
Old Jan 10, 2003 | 11:59 AM
YumVTEC's Avatar
Default Re: Need help. 5 lug ITR/CTR suspension problem. (10K2HVN)
oh yeah, good point.
treeafodo
Nov 19, 2013 03:22 AM
4play4dr
Aug 10, 2006 05:39 PM
akaEsCo01
Aug 3, 2003 02:02 PM
ThePunk
Mar 7, 2002 03:50 PM
