overheating
Its 90' degrees out side and sometimes it starts to overheat. I have a b18b in my 91 crx s, I it never went in to the red area but it goes above normal. Then I will pull over stop shut the car off and let it sit for a couple mins and start it back up and it is in the same spot then I start to drive and it goes back down to normal and it wont over heat anymore for a while any one have anyidea wwhat the problem is thanks
Ok, Your Radiator has two hoses, one on top one on the bottom. After Driving around for a while does the bottom one get hot? Replace your Thermostat You can do it your self, Will not cost more than 15 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplicit ef »</TD></TR><TR><TD CLASS="quote">dont replace it!
best thing to do actualy is to remove it permanently.
just remove it for good, works best!
liek said above is should take 15-30 min.</TD></TR></TABLE>
Having water/coolant running around the motor constantly is not a good idea. Every morning start, your car will take longer to warm up.
But than again, do what you want.
sde780
10
Nov 15, 2019 11:10 AM
Halo
18
Mar 1, 2003 02:51 PM
