Cam Question?
I want Blox cams and was wondering what would work with my setup?
LS crank and rods
b16 pistons
b16 head
skunk 2 manifold
dc sports 4-1 header
with Skunk 2 flat faced .5mm oversized valves with springs and retainers
I just want the biggest cam with out the valve to valve problems
LS crank and rods
b16 pistons
b16 head
skunk 2 manifold
so your saying I have that problem now and just dont know it. When would this most likely happen because when I start the car when it is cold there is a loud metal to metal noise for 3 to 5 seconds and then it goes away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DShowers »</TD></TR><TR><TD CLASS="quote">so your saying I have that problem now and just dont know it. When would this most likely happen because when I start the car when it is cold there is a loud metal to metal noise for 3 to 5 seconds and then it goes away.</TD></TR></TABLE>
That's not your valves.
You have stock cams right now, and your valves aren't THAT big.
I just got to the dyno today and made 172 hp after tuning and that was just a/f. I dont have cam gears yet. I still plan on bigger cams and cam gears in the near future but I think this is a healthy start
Fighterinsnatch
16
Jul 26, 2007 08:02 AM
SOHC_MShue
40
Jan 11, 2004 11:11 PM
