EL Gauge Cluster: Blinker Problem
I just installed my EL gauge cluster in my 93 lude. I replaced the dash harness with one from a 94-96 EL gauge cluster model so it just plugged right up. Everything works perfectly on it except the blinker arrows. When i turn on my blinker either way both arrows flash as if my hazards were on. When i turn my hazards on, the arrows dont blink at all. The blinkers and hazard switch still work on the outside of the car but the arrows on the inside are confused...Anyone know what i can do to fix this?
*edit* I also just noticed that the sunroof, cruise and dimmer switch no longer light up. They all still work but just don't light up...
Modified by snowblind7x at 4:21 PM 8/5/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 »</TD></TR><TR><TD CLASS="quote">mine does this too.
but if you notice, the blinkers still work correctly, it just shows funny on the cluster...</TD></TR></TABLE>
yeah i see everything still works on the outside like it should. Did those 3 buttons to the left of the steering wheel stop lighting up for you too when you put the new harness and cluster in? I dunno about you, but even though the blinkers technically work, little stuff like this bugs me and i want to get it fixed.
haha, I had the same problem. Since you have the entire harness (like I did) you'll have a spare plug that does NOT plug into anything. You need to take the grond wire from this plug and ground it to a metal part on your car and it'll work fine afterwards.
This mystery plug is in the area of the digital clock if you are having trouble finding it, its got three wires but I forgot which one is the ground. I just tried all of them and tested the blinkers to find the right one, good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm »</TD></TR><TR><TD CLASS="quote">haha, I had the same problem. Since you have the entire harness (like I did) you'll have a spare plug that does NOT plug into anything. You need to take the grond wire from this plug and ground it to a metal part on your car and it'll work fine afterwards.
This mystery plug is in the area of the digital clock if you are having trouble finding it, its got three wires but I forgot which one is the ground. I just tried all of them and tested the blinkers to find the right one, good luck.</TD></TR></TABLE>
lol yeah i was wondering about that mysterious extra plug, lol. Thanks a lot man, that really helped. I really appreciate it
I'll try that as soon as I have an extra minute.
This mystery plug is in the area of the digital clock if you are having trouble finding it, its got three wires but I forgot which one is the ground. I just tried all of them and tested the blinkers to find the right one, good luck.</TD></TR></TABLE>lol yeah i was wondering about that mysterious extra plug, lol. Thanks a lot man, that really helped. I really appreciate it
this problem has been covered before, i can't remember the users exact name but he had this problem and found the fix. . it in the archives..
serious!?!? wow thanks, ima have to wake up early some day this week and do that **** asap
This mystery plug is in the area of the digital clock if you are having trouble finding it, its got three wires but I forgot which one is the ground. I just tried all of them and tested the blinkers to find the right one, good luck.</TD></TR></TABLE>serious!?!? wow thanks, ima have to wake up early some day this week and do that **** asap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">good ****....im assuming that extra plug is for that little black box that sits to the right of the clock, does your car have that?? its mounted on a white plastic peice (my car had EL gauges factory)</TD></TR></TABLE>
I have a 92' prelude and installed the harness out of a 96' prelude and both mine and the 96' had the little black box and I hooked everything up correctly, so I'm not sure what this plug is for
Hey, Hella_usdm, do your 3 buttons to the left of the steering wheel still light up? Or did they stop lighting up after you changed your harness? Cause that's what seems to ahve happened to me...
This mystery plug is in the area of the digital clock if you are having trouble finding it, its got three wires but I forgot which one is the ground. I just tried all of them and tested the blinkers to find the right one, good luck.</TD></TR></TABLE>Hey, Hella_usdm, do your 3 buttons to the left of the steering wheel still light up? Or did they stop lighting up after you changed your harness? Cause that's what seems to ahve happened to me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">this problem has been covered before, i can't remember the users exact name but he had this problem and found the fix. . it in the archives..</TD></TR></TABLE>
not anymore. my old name was deleted/banned and all my posts along with it.
and btw, he used a 94-96 EL dash wiring harness. I used my old 92-93
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm »</TD></TR><TR><TD CLASS="quote">mine light up fine, maybe try replacing the bulbs in them. They are only a few bucks from the honda stelarship.</TD></TR></TABLE>
yeah thats the thing. 2 of the 3 were already working and i just replaced the bulb on the sunroof one so they were all working. And then after i did this swap they just all stopped working...
jdmsteveo05
Dec 31, 2006 01:04 PM
