Plastigauge and lube?
Old Aug 4, 2006 | 04:09 PM
PhatBoy5015's Avatar
Default Plastigauge and lube?
When checking clearances, do you use lube on either bearing (such as the opposite bearing that the plastigauge is on)? Or are you not supposed to use lube at all when checking clearances?
Old Aug 4, 2006 | 11:08 PM
sporkcrx's Avatar
Default Re: Plastigauge and lube? (PhatBoy5015)
no lube at all
Old Aug 5, 2006 | 12:41 AM
Garage 808 Hatch's Avatar
Default Re: Plastigauge and lube? (sporkcrx)
^^^^^^^ what he said. stick it in dry
Old Aug 5, 2006 | 06:16 AM
unknown0001's Avatar
if you put the lubrication while putting on plastigage it will not give you the proper clearance specs you are looking for
Old Aug 5, 2006 | 08:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">no lube at all</TD></TR></TABLE>
Well I read a couple places that said lube up the engine side main bearings before you put the crank in, but then it said to make sure that its clean. So I wasn't sure.
Putting the crank in dry won't damage the micropolish I just got done, will it?
Old Aug 5, 2006 | 09:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">Putting the crank in dry won't damage the micropolish I just got done, will it?</TD></TR></TABLE>
no it wont, just make sure that when you are doing the plastigage don't sping the crank.
do the outside cylinders first then the inner two. just be gentle with the crank and you won't damage it when it's dry and clean
Old Aug 5, 2006 | 02:26 PM
postman's Avatar
Default Re: Plastigauge and lube? (Mr.RHTuner)
no lube. gives bad readings
Myroslav69
Southeast (Sales)
19
Mar 20, 2010 09:08 PM
BlwnBlue
Dec 20, 2007 11:43 AM
. a d a m
10
Aug 1, 2007 04:42 PM
JustLooking
Nov 23, 2003 02:12 PM
