Spindle nut question for removing front brake disk, need answer ASAP!
Old Aug 4, 2006 | 09:18 AM
.Slug's Avatar
Default Spindle nut question for removing front brake disk, need answer ASAP!
Ok is it necesarry to remove the spindle nut when removing the front disks? If so, what are some tricks to getting that sucker off quick? I do NOT have access to any air tools.
Old Aug 4, 2006 | 09:21 AM
.Slug's Avatar
Default Re: Spindle nut question for removing front brake disk, need answer ASAP! (n00bcivicowner)
ok did a search and found an answer here:
https://honda-tech.com/zerothread?id=480354
Old Aug 4, 2006 | 09:25 AM
BlueIntegraBoy's Avatar
Yes, you will need to remove it if you want to remove the knuckles. I use a breaker bar + the handle from the floor jack (cheater bar).
Edit: You don't have to remove the nut, if just removing the rotors.
Old Aug 4, 2006 | 09:38 AM
EL Vap133's Avatar
If you only want to remove the front rotors, then no. To remove the front rotors you will need to take the caliper off, and the caliper brakcet. Then the 2 small screws holding the rotor to the hub.
Old Aug 4, 2006 | 09:41 AM
philosofy1's Avatar
Default Re: Spindle nut question for removing front brake disk, need answer ASAP! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">If you only want to remove the front rotors, then no. To remove the front rotors you will need to take the caliper off, and the caliper brakcet. Then the 2 small screws holding the rotor to the hub. </TD></TR></TABLE>
yes but don't forget he will have to use impact driver to remove the screws on the rotors. or he can strip the hell out of the them like i did when i did my very first brake job.
Old Aug 4, 2006 | 09:43 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n00bcivicowner &raquo;</TD></TR><TR><TD CLASS="quote">ok did a search and found an answer here:
https://honda-tech.com/zerothread?id=480354</TD></TR></TABLE>
Old Aug 4, 2006 | 10:00 AM
EL Vap133's Avatar
Default Re: Spindle nut question for removing front brake disk, need answer ASAP! (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
yes but don't forget he will have to use impact driver to remove the screws on the rotors. or he can strip the hell out of the them like i did when i did my very first brake job.</TD></TR></TABLE>
Oh I didn't forget, I just don't know what exactly he needs to do. That's why I didn't even tell him what size sockets he needs to remove the caplipers and brackets.
Old Aug 4, 2006 | 10:14 AM
Crazydave's Avatar
The nut does not need to be removed, but the screws that hold the rotor on probably need to be removed with an impact driver (not an air tool)
Old Aug 4, 2006 | 11:14 AM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">The nut does not need to be removed, but the screws that hold the rotor on probably need to be removed with an impact driver (not an air tool)
i fould a secret for this when changeing my stud use a wrench and fitted it to a 4 head screw it the left on the bottom(the flat 4 head one) i should take pics and post it
Old Aug 4, 2006 | 12:57 PM
o2flow.net's Avatar
Default Re: Spindle nut question for removing front brake disk, need answer ASAP! (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">i fould a secret for this when changeing my stud use a wrench and fitted it to a 4 head screw it the left on the bottom(the flat 4 head one) i should take pics and post it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">yes but don't forget he will have to use impact driver to remove the screws on the rotors. or he can strip the hell out of the them like i did when i did my very first brake job.</TD></TR></TABLE>
OR you could use vise grips on a screwdriver. Attach to the handle, put your weight into it, and turn. Comes loose every time for me
Old Aug 4, 2006 | 01:33 PM
SiYouLater's Avatar
My impact driver didnt work, so I had to drill the **** out of it.
Old Aug 4, 2006 | 01:35 PM
philosofy1's Avatar
Default Re: Spindle nut question for removing front brake disk, need answer ASAP! (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi &raquo;</TD></TR><TR><TD CLASS="quote">My impact driver didnt work, so I had to drill the **** out of it.</TD></TR></TABLE>
yeah i've had to do the same, after i stripped them. LOL!
Old Aug 4, 2006 | 02:36 PM
.Slug's Avatar
I got an impact screwdriver from pep boys for about 11 bucks. Worked great, the screws came out with two taps of the hammer on the screwdriver.
leviq
Nov 17, 2012 02:02 AM
rus
11
Jun 5, 2006 12:01 PM
DIYaccord
22
Aug 10, 2004 06:55 PM
1whitedc2
Jul 16, 2004 10:32 AM
Floyd
Sep 13, 2001 08:57 PM
