GSR Throttle body?!..
Old Aug 4, 2006 | 08:15 AM
VTECth1s's Avatar
Default GSR Throttle body?!..
I have a 97 B18C1, which throttle body size am I suppose to use, 60 or 62 mm? to fit on the stock intake manifold. And/or what size bigger TB can i go with on the stock intake manifold? Thanks!
Old Aug 4, 2006 | 08:31 AM
DC2 Mang's Avatar
Default Re: GSR Throttle body?!.. (egg6vtak)
ditch the stock manifold, it is very rextrictive and I have read threads about the turblent flow that it has due to the butterfly's being closed below 6000 something rpms
Blox, Skunk2, AEBS intake manfiold's are cheap if you find them used, and have a 65mm inlet at the manifold, they will increase high end and back up any aftermarket cams very nicely if you plan to modify your engine further down the road
Old Aug 4, 2006 | 09:10 AM
VTECth1s's Avatar
Default Re: GSR Throttle body?!.. (DC2 Mang)
I actually plan keeping it stock other then I/H/E and chipped ecu which I already have. I plan on selling the car so don't need to spend extra on aftermarkets ..but plan on getting an AP1(S2K) . But what size would fit on the stock intake manifold? Say if go with aftermarket TB but stick with stock mani. thanks for the info!
Old Aug 4, 2006 | 09:18 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
There is no point in getting an aftermarket TB if the port on the stock intake mani doesnt match it. What benefit would u get from putting on a 65mm TB when the stock port is 60mm. U either have to widen the port on the mani to match, get an aftermarket intake mani, or dont bother with it at all since u said u are going to sell it.
Old Aug 4, 2006 | 09:19 AM
DC2 Mang's Avatar
I would use a micrometer to measure the size of the inlet to the manifold, but if youre selling it I wouldnt get an aftermarket throttle body
If yu really want a bigger one send the stock TB out to maxbore and get it bored out to the biggest you can for the stock manifold and it is only $100
Old Aug 4, 2006 | 09:40 AM
VTECth1s's Avatar
Default Re: GSR Throttle body?!.. (rukawa1one)
Well, actually i just need a replacement throttle body, the TPS sensor on mine has malfunctioned according to the CEL code 7. So i was thinking to just get an aftermarket one if the OEM or stock one was nearly the same price. Having trouble finding a used one.
Old Aug 4, 2006 | 01:32 PM
rukawa1one's Avatar
I have a GSR TB for sale, $100 shipped, comes with both working map and tps sensors and FITV valve.
Old Aug 4, 2006 | 01:55 PM
Dogginator's Avatar
Daisy... Daisy...
The bore on my '97 GSR IM fits my 62mm TB perfectly. I bored my 60mm TB to accomplish this.
Old Aug 4, 2006 | 02:04 PM
VTECth1s's Avatar
what year is it off of?...where u located? if close enough ill pick it up
Old Aug 4, 2006 | 05:10 PM
rukawa1one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak &raquo;</TD></TR><TR><TD CLASS="quote">what year is it off of?...where u located? if close enough ill pick it up</TD></TR></TABLE>
I am in 626 area code
I believe its a 94-95 but the sensors use the same plugs as 96-01. THe only diff is the FITV valve that only came on the 94-95 models. Either way its a straight bolt on, the FITV will just use the coolant lines going into your TB right now.
dhabell
Aug 15, 2014 05:42 PM
Ek-Xang
Oct 20, 2010 01:40 AM
ix3mydc
Oct 27, 2009 08:30 PM
Double Agent
Dec 29, 2008 07:44 PM
blazin415
10
Dec 30, 2007 01:20 PM
