codes on my 99 civic si
Old Aug 4, 2006 | 01:00 AM
teamvirus's Avatar
My car breaks a lot!
Default codes on my 99 civic si
any help will be huge!! thanks for your time
P0122 Throttle Position (TP) Sensor Circuit Low Input
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
i have these codes..any idea what the problem could be
Old Aug 4, 2006 | 01:33 AM
teamvirus's Avatar
Default Re: codes on my 99 civic si (teamvirus)
up bump
Old Aug 4, 2006 | 07:39 AM
teamvirus's Avatar
up
Old Aug 4, 2006 | 07:52 AM
-Gary-'s Avatar
Is this a swapped car?
Old Aug 4, 2006 | 07:59 AM
miahmouse's Avatar
I'd start by backprobing the map and tps to see if there's actually anything going on...
Then move on to checking the plugs connectors and wires at both ends
Old Aug 4, 2006 | 11:23 AM
teamvirus's Avatar
Default Re: (-Gary-)
no...stock b16a2, skunk2 manifold
Old Aug 4, 2006 | 01:41 PM
teamvirus's Avatar
bump
Old Aug 4, 2006 | 02:55 PM
cambopheonix56's Avatar
Grounding problem maybe?
Old Aug 4, 2006 | 10:16 PM
teamvirus's Avatar
Default Re: codes on my 99 civic si (cambopheonix56)
no..the car runs pretty good...but i noticed that the rpms go up and down a little bit from maybe 1-1.5 up and down, but settle after a few seconds
Old Aug 4, 2006 | 11:43 PM
teamvirus's Avatar
bumps
Old Aug 5, 2006 | 04:48 AM
teamvirus's Avatar
the rpm's are going from 1k to 2k
Old Aug 5, 2006 | 06:34 AM
bonylad's Avatar
Are they (sensors) connected correct? Not damaged when you swapped the
parts? All the codes cept the TPS are from sensors on the mani (I think)
Old Aug 5, 2006 | 03:18 PM
teamvirus's Avatar
what does this mean??
Old Aug 5, 2006 | 08:38 PM
ci_v_ic's Avatar
check the vaccum hose directly under the 3rd and 4th runner on your intake manifold closest to the driver's strut tower. that should fix your idle surge problem, maybe even your cel problem. it fixed my idle and map.
Old Aug 7, 2006 | 02:13 PM
teamvirus's Avatar
bump
Old Aug 7, 2006 | 04:21 PM
miahmouse's Avatar
have you checked anything anyone mentioned?
Kidnkorner
28
Jun 26, 2010 03:40 PM
xASAPx
Sep 15, 2006 09:21 PM
abmerop18
Jun 4, 2006 06:59 AM
2000civicsi
Oct 15, 2005 07:09 PM
