How do I get my shift linkage off? Cable LS tranny *dumb question*
Old Aug 3, 2006 | 04:13 PM
SpeedingHatch's Avatar
Default How do I get my shift linkage off? Cable LS tranny *dumb question*
So Im parting my car out and pulling the block and tranny out from the shell. I take a gander at the shift linkage and loosen the one bolt. Then I see there is the other bar but I see no way in getting it off so I can take the tranny and block out.
There are no screws, no nuts, wtf?
Its not the circluar end, its the other.
I know Im dumb, but I need some help
Old Aug 3, 2006 | 06:07 PM
zCivic's Avatar
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (SpeedingHatch)
Roll Pin, you need a roll pin remover AKA a punch or use what I always have around AC bracket bolts, works like a charm. Pull back the rubber boot and you'll see a silver clip ring take that off and your at the roll pin
Old Aug 4, 2006 | 08:12 AM
Spec_V645's Avatar
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (zCivic)
If you can't get the pin with a regular punch, use an air hammer and punch to get it started and then tap it the rest of the way out.
Old Aug 6, 2006 | 01:28 PM
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (Spec_V645)
Which pin?
Ive never done a B series trannt before, only H22, hence why I look dumb asking
Old Aug 6, 2006 | 02:46 PM
civicstar's Avatar
hit that pin off
u can either use the pin remover or what i use is a long 10mm bolt and place it on the pin and hit it off with a heavy hammer. a girly tap won't hit it out, that pin is expanded in there so you have to hit it off hard
Old Aug 6, 2006 | 04:09 PM
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (civicstar)
Okay, I was kind of thinking that one. I gave it a few taps before, but now I know I need to give it a good hit. Thanks
Old Aug 7, 2006 | 09:15 PM
jakscivic's Avatar
it will take more than just a good hit. It will take you some time. It has to be on there pretty perfect. But it will come out if you just keep hitting it.
Old Aug 7, 2006 | 11:00 PM
Enzo Speed's Avatar
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (jakscivic)
Be prepared for a sore shoulder...
Old Aug 8, 2006 | 12:37 AM
shorto85's Avatar
Yeah I hate that pin. Takes a few hits to get it out. Just make sure you don't lose it
Old Aug 8, 2006 | 05:41 AM
bluemax189's Avatar
Default Re: (shorto85)
thats called the Bitch pin. everyone knows it and hates it.
Old Aug 11, 2006 | 05:45 PM
stumpyf4's Avatar
Default Re: (bluemax189)
Drop the tranny with the shift linkage attached. When it's on the floor it's easier to put a socket below (to support the shift shaft) then hammer away from above.
Old Aug 11, 2006 | 05:46 PM
stumpyf4's Avatar
Drop the tranny with the shift linkage attached, remove one bolt just below the shifter. When it's on the floor it's easier to put a socket below (to support the shift shaft) then hammer away from above.
Old Aug 11, 2006 | 08:32 PM
BuddhaSiR's Avatar
Default Re: (stumpyf4)
oh how i love my air hammer.
Old Aug 12, 2006 | 10:20 PM
CovertFI's Avatar
Default Re: (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">oh how i love my air hammer.</TD></TR></TABLE>
I am going to have to try that, i have an attachment that would fit.
Old Aug 13, 2006 | 03:40 PM
NJcoupe's Avatar
Espically a custom milled down one i made in school to get them out.
Old Aug 21, 2006 | 07:04 PM
problem_si's Avatar
Aren't these slightly tapered?
I've done them a few times...never had a problem. Guess I'm lucky. I utilized the skinny bolt method myself, works like a charm.
BTW...Speedinghatch....I'm VERY interested in buying the si shell from you, unfortunately I am a brand new user and this lame rule about no pm'ing or posting in some of the forums is getting on my nerves.
I finally have the money to put towards my project, but my current hatch has frame damage I really would like to start over on a good chassis.
If anyone could pass the message on, it would be greatly appreciated.
Thanks
problem_si@hotmail.com
Old Aug 22, 2006 | 12:51 AM
F20Cteg's Avatar
Default Re: How do I get my shift linkage off? Cable LS tranny *dumb question* (problem_si)
That pin was a biatch when I first did it to. Now that pin is easy to get off. What you need is a pair of pliers to hold a 12mm bolt and a 3lbs or higher hammer. A few whacks will get it out no problem.
&gt;&gt;&gt;&lt;&lt;&lt;
Dr.Fixit
Oct 22, 2013 12:42 AM
thundernutz
Sep 27, 2009 04:22 AM
AE_Racer
Dec 12, 2006 07:41 PM
loosestool
Sep 11, 2006 09:59 PM
stegon78
Jun 24, 2005 08:46 AM
