pistions question
Old Aug 3, 2006 | 03:08 PM
vtec-gorilla's Avatar
Default pistions question
will a set of jdm type r pistons fit into a ls block with a ls-vtec set up and will it boost my performance in any way
Old Aug 3, 2006 | 04:01 PM
95 integra's Avatar
Default Re: pistions question (vtec-gorilla)
Do a search, ls/vtecs and how to build them are probably the most covered topic on honda-tech.
Old Aug 3, 2006 | 07:03 PM
Default Re: pistions question (95 integra)
did a sesrch, i just want ta know if a set of b16 pitions with my stock rods Will work with my ls vtec set up and will it allow me to rev to 8k or better without a problem
Old Aug 3, 2006 | 08:06 PM
DC2 Mang's Avatar
get arp rod bolts, the ls rods will need to be slightly shaved to fit the itr pistons on
Old Aug 4, 2006 | 02:44 PM
Default Re: pistions question (DC2 Mang)
i think iam going to go with some p30 b16 pitions instead, and some arp head bolts. cause all i really want to do is rev to 8k
Old Aug 4, 2006 | 11:21 PM
DC2 Mang's Avatar
if you want to rev past 8k arp rod bolts are essential
you might want to get your rods shot peened as well
Old Aug 4, 2006 | 11:46 PM
stewie8apie's Avatar
ls rods were not meant to handle 8k. do your build right the first time and get some aftermarket pistons/rods. u will be much happier in the long run and will be so much more comfortable w/your setup.
Old Aug 5, 2006 | 07:13 AM
unknown0001's Avatar
Default Re: pistions question (stewie8apie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stewie8apie &raquo;</TD></TR><TR><TD CLASS="quote">ls rods were not meant to handle 8k. do your build right the first time and get some aftermarket pistons/rods. u will be much happier in the long run and will be so much more comfortable w/your setup. </TD></TR></TABLE>
since when is that correct? they will withstand 8,9 and 10k no problem. A good amount of the LS/Vtec setups run whatever piston setup with factory LS rods and you rarely you hear about a rod failure. You can run the LS rods but you need to get ARP rod bolts to secture them to the journals.
to the thread creater, do some research! yes it's possible to put in USDM/JDM itr pistons but you need to calculate what your compression ratio will come out to.
using: http://www.zealautowerks.com/
using the jdm P73-00 pistons with a b18b head/block/crank and rods, you get a appx. compression for 11.6:1
using the USDM P73-A0 pistons you get a nicer more streetable compression of 11.1:1
*edit* also forgot to note, it's not that beneficial bumping up your compression without head work. You will need to get the engine tunned once you throw in the P73 pistons and that wont be really worth the outcome unless you save some cash and get some valve springs/retainers and a set of lumpy cams
Modified by Mr.RHTuner at 11:50 AM 8/5/2006
Old Aug 5, 2006 | 09:32 AM
DC2 Mang's Avatar
Default Re: pistions question (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
very true, mine spun very nice up to and sometimes past 8.5k with the arp rod bolts
ive never seen a rod snap, in one case a person took his factory ls rods to 12k because his throttle body got stuck open
he spun main bearings and cracked his crank but the ls rods and arp rod bolts didnt give out
Old Aug 5, 2006 | 10:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">
he spun main bearings and cracked his crank but the ls rods and arp rod bolts didnt give out</TD></TR></TABLE>
exactly.
if you are worried about the rods, get them shot peeined(SP?)
I'd say the only time you'll throw a rod...and your engine is lack of oil and the engine runs dry
wesley_925
Apr 14, 2008 10:01 PM
CapnToll
Sep 18, 2007 03:55 AM
pokmijn
Jul 14, 2007 06:24 PM
imskatencrzy
Sep 30, 2006 07:12 PM
stretracr
Jul 10, 2001 06:21 AM
