00 si Governor question
Old Aug 3, 2006 | 02:39 PM
GSP's Avatar
GSP
Default 00 si Governor question
2000 si b16a2, no engine mods. At what RPM does the governor kick in? I know that 8200 is the redline, but today in first gear I hit about 8300 maybe 8400 on accident. Can the governor be removed by a stupid previous owner? Also a side question , DOHC kicks in about 5600 RPM's but my car NEVER kicks in the first time I take the engine to that RPM after starting. Works great after. Just wondering if it is normal. Thanks
Old Aug 3, 2006 | 03:07 PM
dthug's Avatar
Default Re: 00 si Governor question (GSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSP &raquo;</TD></TR><TR><TD CLASS="quote">2000 si b16a2, no engine mods. At what RPM does the governor kick in? I know that 8200 is the redline, but today in first gear I hit about 8300 maybe 8400 on accident. Can the governor be removed by a stupid previous owner? Also a side question , DOHC kicks in about 5600 RPM's but my car NEVER kicks in the first time I take the engine to that RPM after starting. Works great after. Just wondering if it is normal. Thanks</TD></TR></TABLE>
do you mean VTEC kicks in at 5600 rpm
doch is dual over head cams
Old Aug 3, 2006 | 03:14 PM
GSP's Avatar
GSP
Default Re: 00 si Governor question (dthug)
Im no honda technician, my car gets significantly louder at 5600. It Thought that was the DOHC(im am incompetent when it comes to hondas), but if its the VTEC, The questions the same. Sorry.
Old Aug 3, 2006 | 03:16 PM
skylinetph26's Avatar
Guy your tach is off by a little, usually OE tachs are somewhat off, no big deal
dthug's Avatar
i believe VTEC is supposed to engage at 5600 in a b16 but i could be wrong and the govornor would stop you from passing a certain speed so it you could shift beyond redline then your ecu was chipped to have the rev limiter taken off. i wouldn't pass the redline on a stock motor
GSP's Avatar
GSP
Also I guess I am talking about a rev limiter, not a governor. According to searches it should kick off at 82, but mine didn't. Could the tach be off?
Old Aug 3, 2006 | 03:18 PM
GSP's Avatar
GSP
Yeah I guess so....thanks skylinetph26......i'm slow.
Old Aug 3, 2006 | 03:50 PM
duggy's Avatar
Yes. Your tach is probably off.
Also the reason why you're VTEC doesn't engage whenever you try it the first time is that you have to wait for the car to warm up before you try to engage VTEC.
Old Aug 3, 2006 | 03:55 PM
WONG FRIED RICE's Avatar
- Yes the REV LIMITER SHOULD kick in at about 8200 RPMS.
- Your OEM tach is probably slightly off.
- VTEC is what is happening at 5600 RPM'S.
- The reason it doesn't "kick" in the first time after starting is because VTEC is temperature dependant as well as oil pressure dependant. Sooooo therefore when you first start your engine....it needs to warm up before VTEC will engage. Oh and of course you need enough oil :D
- AND finally yes everything is normal
SiJunkie
Engine Management and Tuning
Jul 9, 2016 09:32 AM
darkcivic90
Jul 21, 2012 02:37 PM
Mfoehrkolb
42
Jul 23, 2008 07:11 PM
andysila
Feb 2, 2005 08:32 AM
MysteryWagon
Feb 15, 2002 03:03 PM
