ECU code 7 help!?...
I saved myself $40+ from having to use a damn ecu scanner...did the DIY version
did it 7 times to make sure the code was consistent and the CEL code came up as 7(TPS) throttle position sensor. Now how do i fix this problem?, do i adjust it clock wise or counter? help!
Depending on what year you have, that more or less means the TPS is shot. Buy a used TPS sensor ($12 or so from what Ive seen) and have a good time getting the old one off or spend $50 on a used throttle body w/ sensors and replace the entire thing.
