GSR motor into 2g integra, question...
Old Aug 3, 2006 | 02:00 PM
T3k C's Avatar
Default GSR motor into 2g integra, question...
What throttle cable do I use for this swap? I got the stock GSR manifold also.
Old Aug 4, 2006 | 03:34 PM
T3k C's Avatar
jfk;ad
Old Aug 4, 2006 | 07:39 PM
HONDA_TYPE_R's Avatar
Default Re: (T3k C)
Someone correct me if I am wrong, but you may need to use the GSR throttle cable for that particular year motor. I think since the TB is at a little different location, the cable is a little longer.
Of course, sometimes just using a different bracket on your manifold or "custom mounting" the stock one will allow you to use your current cable...keep an eye on it though. Sometimes they slip.
Old Aug 5, 2006 | 12:37 PM
T3k C's Avatar
I haven't been able to find the answer to this since so many people just switch out their gsr manifold for a skunk 2 or whatever. Right now it's pretty much zip tied using the stock throttle cable. I'm just going to try the gsr cable. I just wanted to see if anyone knew so that I don't have to go back and forth.
Old Aug 5, 2006 | 02:33 PM
IHTFP's Avatar
Default Re: (T3k C)
check out the engine swap guide on g2ic.com
import-tooner
Jan 25, 2011 05:30 AM
eggsi619
Jun 29, 2009 11:14 AM
DAmnquickDA
Jul 23, 2007 06:14 PM
Charlie Moua
Jun 24, 2004 09:38 PM
memphiss13
Feb 5, 2003 08:51 PM
