pic request for rollcage in a crx
Old Aug 3, 2006 | 01:26 PM
si90rex's Avatar
Default pic request for rollcage in a crx
i wanting to make my own rollcage i can weld and have the pipe i just need to see how the bolt to the frame. i lookin for one thats not every where just over the head and down to the back. or close to it.
thanks
Old Aug 3, 2006 | 02:40 PM
jedubz's Avatar
Default Re: pic request for rollcage in a crx (si90rex)
search much?
Old Aug 3, 2006 | 02:48 PM
si90rex's Avatar
Default Re: pic request for rollcage in a crx (jedubz)
yep nothin that i need, i need to see the over car if it bolts to frame or what the floor bored wont be safe.
Old Aug 3, 2006 | 04:45 PM
D Jaws II's Avatar
If you are intent on doing a bolt in style cage, the only method I would recommend would be the following:
For both the "A" and "B" pillars you need four sets of 1/4" plate about five inches square. First , make your cage, you can choose either a 4 point at a minimum or a 6 point. At each attachment points to the floor you take 2 plates, drill a hole the size of your tubing in one, and drill 4 holes for the needed bolts in both. Use grade 8 hardware, nuts, bolts, washers. The object of the plates is when you have completed the cage, directly below where the down pipes hit the floor pan you will drill a hole in the floor. First place the plate with the hole under the cage and mark where the holes are needed then drill them, the cage will then slip thru the hole and from beneath the car, you take the another plate (no hole in the center) and directly weld it to the cage downpipe. When all four corners below the car are sercurely welded are done, you raise the cage up to the bottom of the floor and using the four bolts sandwich the floor pan with the inside plate, thru the pan to the bottom plate. That is safe.
If you attempt to bolt the cage to the floor pan without sandwiching the pan with plate material on both sides, on impact, it WILL rip out.
HTH
Cheers,
Donnie
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
RaVAGE00
Oct 24, 2005 06:16 AM
elmalouno
Jul 7, 2004 06:05 AM
Nextelbuddy
19
May 27, 2003 12:25 PM
syndicate43
Nov 25, 2002 05:49 PM
