vtec doesn't engage in first gear, other weird things...
Old Aug 3, 2006 | 12:45 PM
.BigSexy's Avatar
most hood white kid
Default vtec doesn't engage in first gear, other weird things...
Ok, so I just finished my h22 swap. I was originally going with a chipped p28 ecu, but put in my JDM p13. I am running a code 23, which is a knock sensor I believe. But vtec won't engage in 1st gear, it just acts like a rev limiter at 6200 RPM. Then in like 2nd and 3rd gear, it sort of shudders at higher RPMs...could the knock sensor cause this? its the only code I have.
Old Aug 3, 2006 | 01:16 PM
.BigSexy's Avatar
most hood white kid
Default Re: vtec doesn't engage in first gear, other weird things... (egcoupe94)
Old Aug 3, 2006 | 02:16 PM
Pullig's Avatar
sounds liike its in limp mode get a knock sensor or do the chipped p28
Old Aug 3, 2006 | 02:42 PM
.BigSexy's Avatar
most hood white kid
Default Re: vtec doesn't engage in first gear, other weird things... (Pullig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">sounds liike its in limp mode get a knock sensor or do the chipped p28</TD></TR></TABLE>
I was running the chipped p28. But I wanted to keep my IAB secondary butterflies...I have a knock in the engine, it just isnt plugged up
Old Aug 3, 2006 | 03:16 PM
.BigSexy's Avatar
most hood white kid
oh and now vtec doesnt engage at all...redlines at 6200, im gonna make a video when i get home and show you what im talkin bout
Old Aug 3, 2006 | 03:24 PM
Chuckles99SH's Avatar
Still the first part of what that poster said holds true, your knock sensor error code sent your ECU into safemode. Try resetting your ECU by either remove battery or clock fuse and see if you still get the code when you start it back up again. Replace the knock sensor if you get the code again and see if you still get the problems.
Old Aug 3, 2006 | 03:27 PM
Yes, if your ECU has a CEL code it will retard timing and wont let you rev above 6500rpm. Fix your knock sensor probem and reset your ECU, dont try to drive your car hard before that because of the ignition timing being retarded.
Old Aug 3, 2006 | 03:41 PM
.BigSexy's Avatar
most hood white kid
Default Re: vtec doesn't engage in first gear, other weird things... (Chuckles99SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">Yes, if your ECU has a CEL code it will retard timing and wont let you rev above 6500rpm. Fix your knock sensor probem and reset your ECU, dont try to drive your car hard before that because of the ignition timing being retarded. </TD></TR></TABLE>
thank you sir...Im gonna see if the mechanic here at work can put my lude on the lift at work, and plug my knock sensor up.
ohsnapzafingcu
Oct 21, 2007 09:21 AM
Jmunk
Feb 23, 2005 04:54 AM
WreckedTeggie
Apr 19, 2004 07:32 AM
gaydm.accord
Mar 8, 2004 03:53 PM
B18G
Oct 7, 2003 09:50 PM
