Check Engine Light Kicked on while driving 75-80mph
Old Aug 3, 2006 | 10:22 AM
SmogKing's Avatar
Default Check Engine Light Kicked on while driving 75-80mph
[B]I have a 89' CRX Si with first gen. B16a swap with a chipped out pw0 ecu. I had no problems until this morning driving to work. I was on the freeway doing about 75-80 then check engine light kicked on, the engine started to surge. Whenever I would try to accelerate the engine would decelllerate, now my Si won't run right. How would I check for codes on the OB0-0 ecu.?
Old Aug 3, 2006 | 10:24 AM
EL Vap133's Avatar
Default Re: Check Engine Light Kicked on while driving 75-80mph (TuaNguyen)
Just look at the blinks, I bet it is a code 22 though cause the same thing happened to me.
Old Aug 3, 2006 | 10:52 AM
SmogKing's Avatar
How would I check the blinks? On the OBD-1 vehicles you would have to bypass a connector by the kick panel on the pass. side and the ecu would go into diagnostic mode then the check engine light would blink if there was a code. Mine does not blink, it stays on. On the OBD-2's if there is i soft code the light would blink, but if there is a hard code the light would stay on. Besides, the OBD-2 has the 16 pin connector plug so you could just plug in a scan tool and check for codes, data. I 'm looking for a way to check for codes, any1 has any solutions?
Old Aug 3, 2006 | 11:04 AM
HondaHeddie's Avatar
Default Re: (TuaNguyen)
crank engine
turn keyone click back from run position(this will leave sys ecu on)
pull down carpet on front passgr side
you will see ecu on firewall
center of the ecu is a red led that blinks, count the blinks
it may show multiple codes (i.e. blink,blink---blink------blink,blink,blink,blink which is codes 2, 1, and 4)
Old Aug 3, 2006 | 11:24 AM
SmogKing's Avatar
That's what I was looking for, Thanx aal.
Old Aug 3, 2006 | 12:48 PM
Voodooboy520's Avatar
You dont need to crank over the engine. It doesnt even need to be running.
hunter fitch
Engine Management and Tuning
Feb 1, 2019 11:12 AM
DamnThatsRexy
Jun 17, 2013 09:58 PM
ethos0518
Aug 13, 2011 07:36 AM
jeremy.
Aug 22, 2003 06:59 AM
type Gendy
Apr 21, 2003 04:48 PM
