nostart. this is a toughie !!!!!!!! need help
Old Aug 3, 2006 | 10:10 AM
jdm Ef-9's Avatar
Default nostart. this is a toughie !!!!!!!! need help
i gota no start on the ef, i did a voltage drop test on starter. checked voltage at battery. fuse box under the hood was replaced last week. and i checked the voltage at the fuse box, and everything is getting voltage..... im guessing its the main engine relay..... if ya think thats it, where is it located??????
thanks
matt
Old Aug 3, 2006 | 10:13 AM
si90rex's Avatar
Default Re: nostart. this is a toughie !!!!!!!! need help (jdm Ef-9)
under the dash above the hood pop. 4X2in black box
91civicEX's Avatar
get a long wire, touch one end of it to the spade terminal on the starter. and touch the other end to the positive battery terminal. if the starter spins then the problem is in the relay or the ign. switch. if it doesnt then u have a bad starter or a bad connection between the main power cable and the starter
Old Aug 3, 2006 | 10:17 AM
jdm Ef-9's Avatar
Default Re: nostart. this is a toughie !!!!!!!! need help (91civicEX)
yea but 91 but im getting the starter to turn over....it cranks......and im getting plenty of spark. fuel pumps fine as well
Old Aug 3, 2006 | 10:20 AM
si90rex's Avatar
try roll start. if its a MT, if it dones't shows like the fuse other the hood
Old Aug 3, 2006 | 10:28 AM
91civicEX's Avatar
Default Re: nostart. this is a toughie !!!!!!!! need help (si90rex)
ok any codes? when did this start? does it sound like its trying to start like a pop everyonce in a while? does it sound any different cranking?
Old Aug 3, 2006 | 10:45 AM
Loserkidwac's Avatar
On your plug wires on correctly? Double check them
Old Aug 3, 2006 | 11:34 AM
jdm Ef-9's Avatar
Default Re: nostart. this is a toughie !!!!!!!! need help (Loserkidwac)
plugs fine.....but every once in a while i gota bump start it....let me go and do that in this hot *** day....brb
matt
Old Aug 3, 2006 | 11:46 AM
jdm Ef-9's Avatar
problem fixed....i just walked away from it and tryed agian an hour later....started right up....wired......lol
thanks for the help
matt
91civicEX's Avatar
if it cranks and wont start then it will start when you bump start it, it must not be cranking fast enough. how does it run after its started? try to start it right after you shut it off to see if the battery is bad, if it starts then i bet its the battery only keeping a surface charge for a short time.
Old Aug 3, 2006 | 11:48 AM
gp70hs's Avatar
If the engine turns over, but doesn't start, try spraying a little carburator cleaner down the throat on the intake. Then try to start it. If it run's for a couple of seconds, then I'd bet your fuel relay is flakey. It's under the side panel, pretty much above the hood release lever. It's right above the starter relay, and you can probably just barely see the nut, above the starter relay. The circuit boards tend to get cracks in the solder joint's. The fix is to purchase a replacement, or pull your's apart and resolder it. I had a problem similar to your's, but just flakiness. Since I pulled the relay and resoldered it I've not had a problem.
tvdc2
Jul 29, 2016 08:48 AM
MyHotsh
50
Apr 21, 2010 03:30 PM
1Bluegsr
Oct 3, 2007 01:47 PM
CRX7
Aug 29, 2005 01:42 PM
Cliff Huckstable
Jul 14, 2004 09:04 AM
