81mm Pistons in GSR?
Old Aug 3, 2006 | 09:49 AM
bjfisher's Avatar
Default 81mm Pistons in GSR?
i just got 81mm JE pistons for my gsr, and now im kind of wondering if i should have went with 81.5mm. what do you guys think? will i be ok? the block is good at 163k miles currently
Old Aug 3, 2006 | 05:00 PM
NJIN BUILDR's Avatar
Default Re: 81mm Pistons in GSR? (bjfisher)
Have a machine shop measure the bores.Personally I would go oversize and get the bores round and straight again.
Old Aug 5, 2006 | 05:40 AM
bjfisher's Avatar
yeah i understand what you are saying, but i already have these pistons :s
Old Aug 5, 2006 | 02:45 PM
Default Re: (bjfisher)
If your going to use them because "I already have them" then why ask the question.
Old Aug 10, 2006 | 08:41 AM
bjfisher's Avatar
just trying to see how big of an issue it would/could be
Old Aug 10, 2006 | 01:57 PM
civicstar's Avatar
yeh i suggest you measure the bore and measure the piston ring gap. ive ran std bore on many blocks but ive noticed that if the block has over heated a few times, the gap is to big and the piston rings don't seal. As long as the gap is ok, then its fine to run std bore
Old Aug 10, 2006 | 02:11 PM
bjfisher's Avatar
thanks for the info. if its only over heating i have to worry about, im willing to bet it has been ok bc the car has been VERY well taken care of.....i guess we'll see.....
MikeSarr_GSR
Sep 25, 2007 05:45 PM
5_Lug_B
Aug 5, 2007 09:26 PM
spoolingb20
Mar 30, 2007 08:19 PM
speedy108
Dec 26, 2002 07:37 AM
LSVTEC408
Nov 21, 2002 04:42 PM
