LS motor(P75) in a GSR frame(P72) - Problems?
Old Aug 3, 2006 | 08:59 AM
lsturbo*'s Avatar
Default LS motor(P75) in a GSR frame(P72) - Problems?
I have a LS setup I will be installing into a GSR shell that I got from the auction. I was wondering if the wiring will match besides the VTEC wiring. I believe all of the harnesses will fit together, but will I see any other problems in this match up? It is a 98 LS motor(with ECU) going into a 98 GSR shell(with no ECU - just wiring harnesses).
Thanks...
Old Aug 3, 2006 | 09:11 AM
H23 Power's Avatar
Default Re: LS motor(P75) in a GSR frame(P72) - Problems? (lsturbo*)
should be plug and play
Old Aug 4, 2006 | 06:57 PM
vladd's Avatar
it'll be plug and play for the most part. when we were doing my brother's ls engine into gsr body i remember we had to change the heater valve on the firewall to the ls one cuz the gsr one needed a longer hose, the evap tank had to be modified a bit, and the tb cable needed to be changed to ls. other than that, everything should be the same.
Old Aug 4, 2006 | 07:44 PM
blkb18's Avatar
As stated before, the water control valve is a little different. In regards to wires, check out http://www.ff-squad.com, this site has great schematics, you will have to swap one pinfit at the ecu connector A, swap the red wire from pin 26 to pin 15, on a gsr harness this is the intake air bypass control solenoid which your ls motor doesent have. Swapping the pins at the ecu connector will change it to the evap vsv and will keep you from settin a check engine light, i am pretty sure thats all you have to do. I just did a gsr swap into an ls and thats the only wire i had to change with exception of running vtec wires. Good luck.
Old Aug 4, 2006 | 07:55 PM
HONDA_TYPE_R's Avatar
The stuff for the IAB's on the IM won't go anywhere. You may need to extend a couple wires, not 100% sure though.
bitzbp
Jun 9, 2012 05:34 PM
tweensquirt
Free Stuff
Feb 4, 2010 04:56 AM
Msnier85
Dec 26, 2006 09:25 PM
CompanyFlow
Dec 5, 2004 06:37 PM
TRE_
May 4, 2004 08:39 AM
