power steering leak
Old Apr 23, 2002 | 08:17 PM
fiebru1119's Avatar
Default power steering leak
i am leaking power steering like mad. the whole area around the pump and the thing you put the fluid in is covered with fluid. the pump looks intact, and all the lines are like new. what could be wrong? any GSR owners had PS leak problems? will it leak if you have too much fluid in the lines? i know the lever fluctuates, i wonder if i over filled it
Old Apr 23, 2002 | 08:30 PM
MrFatBooty's Avatar
Default Re: power steering leak (fiebru1119)
You may have a bad seal inside the pump. Either that or maybe one of the pressure lines could be installed wrong.
Old Apr 24, 2002 | 11:22 AM
SIK IN DA HED's Avatar
New User
Default Re: power steering leak (MrFatBooty)
usually its a bad seal or the hose is clipped. i had a problem with both. had a tear in the hose that i didnt notice.. and the seal was bad.
Old Apr 24, 2002 | 02:35 PM
IN VTEC's Avatar
I do...seal by the pulley is leaking and throws small amounts of fluid over the back of the headlight assembly and the bottom of the hood.
91akira
Jul 27, 2017 10:16 PM
nexusRawr
Nov 14, 2016 06:22 AM
professorman
Feb 24, 2012 06:52 PM
fackyou
Aug 6, 2006 01:29 PM
roydogg
Jul 17, 2003 11:12 AM
