Some AC questions, regarding D and B interchangability and a JDM y0 question
Old Aug 2, 2006 | 09:48 PM
E36 Guy's Avatar
Default Some AC questions, regarding D and B interchangability and a JDM y0 question
Ok so heres the deal.
I have a 1993 JDM EG4 (has a D15b now) which I got as a shell. The car originally had AC from the factory, but the previous owner pulled it out. The underdash is still there though.
Now, I found a guy with a JDM EG6 (with a b16) and he is willing to sell me the AC from his car. His car is a 1992. First question, did japan convert to r134a in 1994 like the USA? or earlier/later? I need to know if i have to convert it to r134a.
Next question, my car has a D series, his a B. Will the compressor still bolt up to my engine block? if not, what do i need?
Thanks!!
Old Aug 3, 2006 | 02:19 AM
frknlo87's Avatar
bump.
i would also like to know
Old Aug 3, 2006 | 11:33 AM
E36 Guy's Avatar
Default Re: (frknlo87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frknlo87 &raquo;</TD></TR><TR><TD CLASS="quote">bump.
i would also like to know</TD></TR></TABLE>
me too!
Old Aug 3, 2006 | 11:47 AM
SicilianSpeed42's Avatar
Default Re: (WHACK EG4)
I dont know when Japan converted, but if it is r12, the conversion is quite easy, especially because you wont have to vacuum it. (WARNING be careful when putting the fittings on, the necks of th A/C pipes like to rip off when the temp outside is over 100) Im not sure about the compressor fitting, I know you can bolt a D compressor to a B block, but Im not sure if it works the other way around
Old Aug 3, 2006 | 12:57 PM
E36 Guy's Avatar
Default Re: (SicilianSpeed42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know when Japan converted, but if it is r12, the conversion is quite easy, especially because you wont have to vacuum it. (WARNING be careful when putting the fittings on, the necks of th A/C pipes like to rip off when the temp outside is over 100) Im not sure about the compressor fitting, I know you can bolt a D compressor to a B block, but Im not sure if it works the other way around</TD></TR></TABLE>
Thanks for the responce.
what do you have to do to convert r12 to r134a??
Old Aug 3, 2006 | 01:31 PM
philosofy1's Avatar
to use the a/c compressor from a dseries onto the bseries engine still using a d-series components (lines, condensor, etc.) you will need 1 of 2 compressor brackets.
you can find them at the dealer
part# 38930-P54-000
part# 38930-P7J-000
Old Aug 3, 2006 | 06:15 PM
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">to use the a/c compressor from a dseries onto the bseries engine still using a d-series components (lines, condensor, etc.) you will need 1 of 2 compressor brackets.
part# 38930-P54-000
part# 38930-P7J-000</TD></TR></TABLE>
he is doing it the other way around though, b series compressor on a d block
All you need to convert are the r 134a fittings ($7 at autozone), and then get some bottles of r134a pre mixed with oil, you can get a retrofit kit for like $30-40 at any car parts store that comes with everything you need, or piece it together yourself.
Old Aug 3, 2006 | 06:34 PM
EJ8VTEC's Avatar
Mr. Indecisive
part# 38930-P54-000
Old Aug 4, 2006 | 08:28 AM
E36 Guy's Avatar
part# 38930-P54-000
Thanks but im going B compressor and lines on a D block...
Old Aug 4, 2006 | 08:51 AM
philosofy1's Avatar
eewww....that's going to be hard, being that the b series compressor is the larger of the 2 compressors, you won't find a oem mount for the d series block. in your case why don't you just change the a/c lines.
Old Aug 4, 2006 | 09:00 AM
E36 Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">eewww....that's going to be hard, being that the b series compressor is the larger of the 2 compressors, you won't find a oem mount for the d series block. in your case why don't you just change the a/c lines.</TD></TR></TABLE>
Cause i need RHD lines and i cant find D series ones anywhere
Old Aug 4, 2006 | 09:12 AM
Luserkid's Avatar
You could go to a place like hose king or someone like them and they could probably make you up the pipes you need. Just take the B series end links and use your D series lines and theyll make it fool proof.
Old Aug 4, 2006 | 10:27 AM
eggie75's Avatar
not sure, but i would guess an eg w/ b series is prob gonna be like the del sol. the compressor that fits on the del sol bracket is a d compressor isn't it?
Old Aug 4, 2006 | 10:39 AM
philosofy1's Avatar
Default Re: (eggie75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">not sure, but i would guess an eg w/ b series is prob gonna be like the del sol. the compressor that fits on the del sol bracket is a d compressor isn't it?</TD></TR></TABLE>
one of them is, but in his case it's totally different.
to the op, your best bet is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You could go to a place like hose king or someone like them and they could probably make you up the pipes you need. Just take the B series end links and use your D series lines and theyll make it fool proof. </TD></TR></TABLE>
Old Aug 4, 2006 | 10:44 AM
E36 Guy's Avatar
OK im a bit confused. is the only difference between D and B series AC systems the compressor????
DC2_ITR
Mar 21, 2007 06:38 AM
EK k kay
Sep 23, 2005 03:46 PM
my01accordex
Jul 4, 2004 11:02 PM
