Gauge cluster swap
Just did it into a 92 CX. 15 min max
Pop off the harzard surround piece
pull out hazard button and dis-connect
undo philips head screw behind hazard button
undo the two philips screws under the top of the cluster cover(right above steering wheel...use a short screw driver)
carefully work out cluster cover.
undo 4 philips holding in cluster
unplug plugs (4)
grab new cluster
plug in plugs (4)
screw in the 4 philips....blah, blah...you get the idea.
Good luck!
unplug plugs (4)
grab new cluster
plug in plugs (4)
Good luck!
