boost on stock axles
my boosted rex project is almost done, will i be able to run the stock axles with some ET streets?? i havea 4000 rpm two step im gonna be dumping it at that, i hope the clutch will hold up, but i was wondering about the axles, i will replace them soon but will one launch at 4000 on some drag radials leave me sitting at the light?
If youre nervous buy another set, if they break replace, then go back and get new ones with the warranty. Once I was doing something that involved take off the shock assembly and forgot to put the bolt back in and droppped the fork onto the axle and ripped the boot, took it back and got another ha.
http://www.raxles.com/
things are indestructable.
you can also go oem and do the swap at autozone all the time if thats your thing.
either way itll work out fine.
one costs more but is less work for you in the long run...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mintef »</TD></TR><TR><TD CLASS="quote">i say stock axles, its like the fusible link of a drivetrain..........better of breaking axles than a tranny</TD></TR></TABLE>
hell yeah, that works, **** i work at advance so i should know how to screw them with warrenty ****. Cool cool, i will try them, whats the worst that could happen (last famous words)
AW
Oct 11, 2005 12:15 PM
vtecmike1
Apr 1, 2004 10:19 AM
