parking brake pin
Old Aug 2, 2006 | 04:26 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default parking brake pin
Seized where it's attached to the caliper. Anyone know a trick on how to get it out?
Old Aug 2, 2006 | 04:31 PM
Tyson's Avatar
Default Re: parking brake pin (ILcrxsi1)
disc or drum???
not sure what pin youre talking about.
Old Aug 2, 2006 | 04:33 PM
ILcrxsi1's Avatar
Default Re: parking brake pin (Tyson)
disk, the pin that connects the parking brake cable to the actuator. I'll get a pic
Old Aug 2, 2006 | 04:34 PM
Tyson's Avatar
ive rebuilt my rear calipers before. dont remember ever having an issue.
Old Aug 2, 2006 | 04:35 PM
ILcrxsi1's Avatar
http://www.hondaautomotivepart...BRAKE it's #1 in on that page
Old Aug 2, 2006 | 04:36 PM
Tyson's Avatar
well, i dunno what to tell you. did you take the cotter pin out?
Old Aug 2, 2006 | 04:39 PM
ILcrxsi1's Avatar
yes, I took the cotter pin out but the pin won't budge. it's rusted in there pretty good. the cable and everything is fine it's just the caliper that needs to be replaced and this pin is holding me up
Old Aug 2, 2006 | 04:43 PM
Tyson's Avatar
pb blaster??
i dunno man. take a needle nose plier and pull it out.
Old Aug 2, 2006 | 04:44 PM
d16efsedan's Avatar
use wd-40 or something and let it sit for awhile then knock it out...
Old Aug 2, 2006 | 04:54 PM
ILcrxsi1's Avatar
Default Re: parking brake pin (d16efhatch)
I've got pb blaster on it ******* thing won't bugde. even stuck a big flathead screwdriver underneath it and tried to pry it up and out.
I swear I run into the most stupid ****
Old Aug 2, 2006 | 04:55 PM
Tyson's Avatar
cut it off, drill it out.
its a $1.83 piece.
Old Aug 2, 2006 | 05:16 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">cut it off, drill it out.
its a $1.83 piece.</TD></TR></TABLE>and a $30 drill bit set
Old Aug 4, 2006 | 05:07 PM
ILcrxsi1's Avatar
Pedal feels spongy, I don't know if it's because of the new brakes and it's just in my head or if there is still air in the system. I didn't bleed the front after I replaced the rear maybe that's the problem.
Old Aug 4, 2006 | 05:49 PM
EFMENOEFU's Avatar
did you replace the prop valve? master cylinder?
Old Aug 4, 2006 | 06:18 PM
ILcrxsi1's Avatar
Default Re: parking brake pin (EFMENOEFU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFMENOEFU &raquo;</TD></TR><TR><TD CLASS="quote">did you replace the prop valve? master cylinder?
</TD></TR></TABLE>nope, I just went for a drive, it's just all in my head. I guess I was just too used to two seized calipers and warped rotors
Old Aug 4, 2006 | 09:00 PM
ILcrxsi1's Avatar
Default Re: parking brake pin (jason_alt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason_alt &raquo;</TD></TR><TR><TD CLASS="quote">You could have placed a c-clamp on the pin. On one side of the pin, place a socket with an inside diameter that's bigger than the outside diameter of the pin. Tighten the c clamp which is fastened to the pin on one side, and socket on the other side. The pin will move with enough clamping pressure. The clearance you've provided with the socket gives the pin room to slide down. Then tap the rest of it out. </TD></TR></TABLE>probably could have worked but I just drilled
92ReD_H23
Jul 6, 2008 07:09 PM
Nisif
Jun 6, 2008 07:43 PM
1greatEG
Mar 23, 2008 08:37 PM
Turbo Dan
Aug 8, 2006 07:05 AM
92b16vx
Sep 22, 2003 09:56 AM
