Help removing the clevis pin for the E brake cable.
Well I got the E brake cables for my rear disc conversion today, and I went to put them on and I ran into a problem. The clevis pin that holds the ebrake to the caliper is not coming out. I removed the saftey wire, and it still isn't budgeing. What am I missing here? seems as though it should come right out, but it isn't.
Re: (92b16vx)
Pound on it with a hammer.
They should slide right out. It could have galled and is stuck, but a hammer should fix that.
Don't forget to release the parking brake
Re: (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">Pound on it with a hammer.
Don't forget to release the parking brake </TD></TR></TABLE>
The trialing arms are in my basement. THere is a lip on the top, so I don't know how well pounding them out that way would work.
Re: (92b16vx)
then pound on it from the other side using a screwdriver.
When something is stuck, what do you typically do?
I typically pound/pry on it with bigger and bigger hammers/screwdrivers until it comes out.
If that fails then I take out the drill or torch.
Kennydee
10-29-2006 08:22 AM
udm_motorsport
03-10-2004 06:17 AM
