Should I replace throttle body?
My car threw a code and I and got it read and it was "pedal position sensor" shop said that im going to have to replace my throttle body. I wanted to know if it is worth getting a bigger throttle body or if I should just replace with oem. I got dc headers with collector mod to 2.5 inch and custom 2.5 inch exhaust and aem CAI. No other mods. thanks!
Guest
Posts: n/a
The USDM TPS sensors were riveted onto the TB, whereas the JDM have screws and are adjustable! The reason for this being the emissions in the USA. You could just lookaround for a JDM OEM throttle body and sensor so if you ever have future problems with your TPS it is cheaper and easier to fix. Or if you have the resourses drill and tap your current TB for the TPS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">The USDM TPS sensors were riveted onto the TB,</TD></TR></TABLE>
They are not rivets. They are screws that twist off when installed to leave a blank head. Go to a scrap yard with a hacksaw and a flat screw driver. Find just about any honda TB and notch the blank screw heads with the hacksaw, then unscrew them and remove the sensor.
I have done this several times. That sensor sticks out so it always gets smahsed when an engine is shipped on a pallate and I have to find replacements.
