wont start
Old Aug 2, 2006 | 01:04 PM
tasco's Avatar
Default wont start
ok im about to throw my car in the trash. this morning i went to go start my car to fix the tach the don't work, and it start but then it started ideling rough and then sputtered and stopped running. so then i tried it again it started but idled even rougher so i did it a couple more times and it just idled a few seconds and quit. and now i try to start it and it wont run at all , i don't know if this has anything to do with it but when it did run, when i got around 40mph or ran the car long or hard at all it would stutter. ahhh my car is starting to **** me off. can anyone lead me in the right direction on what to check. by the way its a 92 ls
Old Aug 2, 2006 | 01:12 PM
crx_88_si's Avatar
does the check engine light stay lit?
Old Aug 2, 2006 | 03:18 PM
tasco's Avatar
Default Re: (crx_88_si)
the check engine light goes off after a couple seconds.
Old Aug 2, 2006 | 08:05 PM
jared99's Avatar
Default Re: wont start (tasco)
Disconnect o2 sensor, check for vacuum leaks, clean the map sensor, replace fuel filter, could be something related to plugs/wires/distributor/ignition...
Old Aug 5, 2006 | 12:07 PM
docctorwho's Avatar
my 1990 is doing the same thing...is the ecu throwing any trouble codes... mine is throwing a 43...? you could try spraying some starting fluid in the intake to get it started.
Old Aug 6, 2006 | 12:30 PM
CASTUDILLO01's Avatar
try to see if your getting spark. good chance that it may be a ignition coil or igniter inside the distributer. check to see if your getting spark if not those might be your problem start their also might be main fuel relay if your not getting fuel.check to see if fuel pump kicking on when you turn the ignition key to the second marks but not turning the motor over.
Old Aug 6, 2006 | 01:30 PM
sirg-vtec's Avatar
Is it getting gas? check the pressure.
Old Aug 8, 2006 | 11:15 AM
docctorwho's Avatar
Default Re: wont start (sirg-vtec)
well in mine i took the bolt out of the fuel filter on the intake side of the filter, turned the key to the run position and gas did flow out, and when i movet the key to the start position it flowed out, how ever my experence with fuel pumps is that the gas shoud squrt out like a water fountain. it is comming out like a bucket over flowing rather then a like a hose.. should it squrit out? like stream out??? I dont think i have enough pressure...cant tell though i dont have a gauge, and cant find the right one anywhere.
as far as the relay goes i have it jumped, i know its faulty will replase it soon.
Old Aug 18, 2006 | 09:49 AM
tasco's Avatar
Default Re: wont start (docctorwho)
so i went to start the car up the next day and it started. so i drove down the road a couple miles went to the store and on the way back it started stutering again. and when i was going around a curve it sputtered and and turned off. i tried cranking it up again and it started kinda back firing a few times. pushed it off the road. waited a few minutes and finally turned on again. i had to keep the revs high to get back home. do you think it could be the fuel filter? help im stumped.
Old Aug 18, 2006 | 11:21 AM
tasco's Avatar
ok so i went to change my sparkplugs and i seen green fluid in the cylinder. this sucks
Old Aug 18, 2006 | 11:42 AM
yee SERIOUS's Avatar
seems kind of like an ignition probelm. but that green fluid is...uh...not good.
Old Aug 18, 2006 | 12:18 PM
tasco's Avatar
Default Re: (undercoverdc2)
is there anything other then the head gasket that could be causing coolent to get in the cylinder?
RobertoHdz
14
Oct 10, 2018 01:15 PM
osbunjosh
12
Mar 3, 2013 12:20 PM
brad22486
20
Mar 24, 2012 09:08 AM
tdc
Jul 19, 2003 12:44 AM
