Suspension & Brakes Theory, alignment, spring rates....
Rear Sway Bar Install Q
Old Aug 2, 2006 | 11:27 AM
Jwcivic's Avatar
Default Rear Sway Bar Install Q
Is the correct way to install it with load on the suspension?? I heard its not a good idea to jack it up (ie. wheels off the ground.) and then install. Any comments?
Old Aug 2, 2006 | 11:39 AM
Tyson's Avatar
Default Re: Rear Sway Bar Install Q (Jwcivic)
doesnt matter if the wheels are off the ground. it would be ideal and easiest to install them with either both wheels off the ground, or resting. as long as theyre the same and one side isnt loaded.
Old Aug 2, 2006 | 11:46 AM
StuDizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwcivic &raquo;</TD></TR><TR><TD CLASS="quote">Is the correct way to install it with load on the suspension?? I heard its not a good idea to jack it up (ie. wheels off the ground.) and then install. Any comments?</TD></TR></TABLE>
Just remember that you torque the bolts the right amount when installing too. There are some websites you can look up the recommended amounts to torque the bolts.
Old Aug 2, 2006 | 08:26 PM
speedjunky01's Avatar
http://www.jdmuniverse.com/for...ybars
Swaybars Explained By: phunhaus
http://www.hazone.com/hsirearsway.htm
swYBr instl
best wtie up I have ever seen
Old Aug 3, 2006 | 08:36 PM
E-Money's Avatar
when jacking it up on a jacking point, place a jackstand on the lower control arm. This applies a load that is necessary for bushing install. Otherwise your gonna rip them straight out when you torque them down with no load on them.
Old Aug 3, 2006 | 08:48 PM
cruizinmax's Avatar
Default Re: Rear Sway Bar Install Q (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">when jacking it up on a jacking point, place a jackstand on the lower control arm. This applies a load that is necessary for bushing install. Otherwise your gonna rip them straight out when you torque them down with no load on them. </TD></TR></TABLE>
Not on a swaybar bushing. They're designed to slide in the bushing. What you are saying may be true on a control arm bushing because the center is bonded to the rubber. Even then though you probably wont tear them, you would just have a slight preload on the bushing.
Old Aug 5, 2006 | 08:18 AM
E-Money's Avatar
Default Re: Rear Sway Bar Install Q (cruizinmax)
is it different with macpherson strut?
Old Aug 5, 2006 | 09:10 PM
cruizinmax's Avatar
Nope.
kcjohnnyboy
Suspension & Brakes
Mar 23, 2008 06:31 PM
CTRwannaB
Apr 23, 2006 10:51 PM
DC238
Dec 27, 2003 11:54 AM
AcCorD 9dfive
Oct 5, 2003 02:47 PM
Raocorp
Jun 18, 2003 02:23 PM
