cam gear installation
Old Aug 2, 2006 | 11:07 AM
Po0r LiTTle CoUpe's Avatar
Default cam gear installation
I need step by step instructions on adj. cam gear installation on my b18c1
anyone know where i can find such things??
Searched couldet find
Thanks
-Randy
Old Aug 2, 2006 | 12:17 PM
civicstar's Avatar
Default Re: cam gear installation (Po0r LiTTle CoUpe)
well you can do it two ways, either by taking the cam off completely or leaving it on the head. a good tool to have is a compressed impact gun to shoot the 14mm bolt off. because if you try to take it off with a regular socket and wrench on the head, you might turn the whole cam and risk bending the valves.
1. Take off Valve cover and plastic cam cover
2. Loosen Timing belt Tensioner and remove belt
3 (You can either change it on the head or take the entire cam off the head, thats up to you) take off the 14mm bolts on both cam gears
4. Remove the cam but do not lose the pin inside either of the cams.
5. Make sure your new adj cam gear is set to 0,0 (stock for now) and is tightened so it doesnt slip
6. Place the in on the cam and slide the cam gear in. make sure the pin is not backwards
7. Place the bolt back in and tighten it with the impact gun or socket/wrench
8. Put the timing belt on and put it on TDC and set timing
9 Tighten timing tensioner
10. Put valve cover and plastic cover back on
Old Aug 2, 2006 | 04:17 PM
i shouldent have to take the belt compleatly off right? just slip it off the cam gears...
am i right?
Old Aug 3, 2006 | 01:11 AM
civicstar's Avatar
Default Re: (Po0r LiTTle CoUpe)
just slip it off and then change the gears
Old Aug 3, 2006 | 06:38 AM
how do i keep the cams still while impacting them?
Old Aug 3, 2006 | 08:16 PM
civicstar's Avatar
thats why i just take it off the head completely, and hold it with a towel but on the head, u have to put it at really high PSI and shoot it off fast
kornerk12
Dec 5, 2008 11:48 AM
integlstrike1
Aug 13, 2006 07:45 AM
NoVtecLs
Oct 10, 2004 11:01 PM
Luserkid
Mar 27, 2003 09:03 AM
boostin b16
Mar 18, 2003 07:13 PM
