After installed Ground Wire, motor oil light came on...Anyone help plz.
Old Aug 2, 2006 | 10:19 AM
1997_prelude's Avatar
Default After installed Ground Wire, motor oil light came on...Anyone help plz.
DO i need to do a oil change or I made some mistake when I installed the ground wire? Thanks.
Old Aug 2, 2006 | 10:30 AM
Hawkze_2.3's Avatar
Default Re: After installed Ground Wire, motor oil light came on...Anyone help plz. (1997_prelude)
You mean the oil pressure light? That's bad and I would remove your ground wires right now and fix it.
Old Aug 2, 2006 | 10:33 AM
SKDRCR's Avatar
Default Re: After installed Ground Wire, motor oil light came on...Anyone help plz. (Hawkze_2.3)
Oil level is good?
Old Aug 2, 2006 | 11:01 AM
chitownrida's Avatar
Default Re: After installed Ground Wire, motor oil light came on...Anyone help plz. (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">Oil level is good?</TD></TR></TABLE>
x2
then go from there
Old Aug 2, 2006 | 12:25 PM
darkspector2.0's Avatar
that shouldn't happen... take off your ground wires and see what happens
Old Aug 2, 2006 | 12:42 PM
thanks for you guys. it seems like an oil level light, it's kinda like a kettle with a drop beside it.
Old Aug 2, 2006 | 04:31 PM
usually means your low on oil...
Old Aug 2, 2006 | 05:06 PM
ViZ's Avatar
ViZ
Well you could have been creating the ground that the light needed to start out with and so it finally came on.
Or you could have the ground hooked up so that its grounding out a circuit creating a closed circuit for that light regardless of its reading.
Old Aug 2, 2006 | 05:11 PM
SKDRCR's Avatar
Default Re: (ViZ)
Where and why did you install this ground wire?
Old Aug 2, 2006 | 08:27 PM
Default Re: (SKDRCR)
Yeah, I checked the oil, it's acutally lower than it should be. Now it starting to make sence: the oil level light is not that bright compare with other indicate lights. So I guess it should turn on when the ground wire was not installed. The ground wire just made it more visible.
Old Aug 2, 2006 | 08:35 PM
Mykizism's Avatar
Default Re: (darkspector2.0)
no.... oil light should never come on.. if it does SHUT THE ENGINE DOWN, AND DO NOT RUN IT WITH THAT LIGHT ON.. if you kept the engine going... YOU PROBABLY KILLLED YOUR BEARINGS....
oil light is not a level meter.. if its on IT MEANS YOU HAVE NOOOO OIL PRESSURE
NO OIL PRESSURE MEANS KILLED BEARINGS...IF you continued to run it..
pretty much OIL LIGHT means DEATH about 99% of the time.. if you dont shut it down right away..
gorthjr
Jan 3, 2016 08:34 PM
hatchylife
Sep 30, 2015 01:59 PM
accordmatt
Mar 11, 2011 09:31 PM
djsire
Aug 11, 2006 02:24 PM
st0nedstoopid
Aug 19, 2003 06:43 PM
