Conv harness not a/c compatible??
Old Aug 2, 2006 | 10:03 AM
ekay. jay's Avatar
Default Conv harness not a/c compatible??
Well iv had my ls/vtec in my 96 ek for ahwile now and recently decided to put my a/c back in. Im running a chipped p28 w/chrome and a obd-2 to obd-1 conv harness.
My problem is the compressor nor the pressure switch is getting any power. Iv heard that some conv harness's arent a/c compatible and you have to swap a few wires around to get the a/c to work.
Can anyone help me out?? Its hot as expletive!!!!
Old Aug 2, 2006 | 10:59 AM
ekay. jay's Avatar
Default Re: Conv harness not a/c compatible?? (ekay. jay)
no one?
Old Aug 2, 2006 | 11:30 AM
98-00's Avatar
bump. i want to know as well.
Old Aug 2, 2006 | 11:59 AM
ekay. jay's Avatar
Default Re: Conv harness not a/c compatible?? (98-00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-00 &raquo;</TD></TR><TR><TD CLASS="quote">bump. i want to know as well.</TD></TR></TABLE>
same problem eh?
A friend of mine had a sk2 conv harness and it would not let him use his a/c. called up skunk 2 and they sent him a new one, now his a/c works.
Old Aug 3, 2006 | 07:23 AM
ekay. jay's Avatar
Old Aug 3, 2006 | 03:59 PM
ekay. jay's Avatar
Old Aug 3, 2006 | 06:16 PM
ekay. jay's Avatar
Old Aug 3, 2006 | 06:20 PM
B18C EG2's Avatar
From: Home Of The Players And PIMPS, IN, united states
jay........
yep....another reason why the EK had to go.....conversion harness's here and there...no AC....
but yeah the sol has neither or that ethier
bump for Jay tho...help.!
Old Aug 3, 2006 | 06:26 PM
ekay. jay's Avatar
Default Re: Conv harness not a/c compatible?? (B18C EG2)
Its been gone over before, but i cant find the thread's. By the time someone helps me summer will be over lol
Old Aug 3, 2006 | 06:49 PM
B18C EG2's Avatar
dude i know how you feel
its freakin soo hot i wanna get AC bangin in the sol...
but today was cold out compared to the other day...so what the hell...
Old Aug 4, 2006 | 04:30 AM
ekay. jay's Avatar
******* hott!!!!
Old Aug 4, 2006 | 07:09 PM
ekay. jay's Avatar
ttt
Old Aug 7, 2006 | 07:09 PM
ekay. jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay. jay &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
Old Aug 7, 2006 | 07:56 PM
b18ccivics's Avatar
ok ekay. jay
your car is a 98 right and going to obd1 so
pin a15 on the obd1 shoud go to pin a17 on your car (ac clutch relay)
pin b5 on the obd1 should go to pin c5 on your car (ac input switch)
that should work
Old Aug 10, 2006 | 11:18 AM
ekay. jay's Avatar
Default Re: Conv harness not a/c compatible?? (b18ccivics)
my car is a 96. does it matter?
Old Aug 10, 2006 | 02:35 PM
b18ccivics's Avatar
no 96 = 98
Old Aug 10, 2006 | 02:39 PM
QuickDxEk's Avatar
I have just a no named brand conversion harness and it works fine!! It might be a problem with skunk 2. Do a search for ecu pinouts for your car. Look at the diagram and see if you can find a place for your A/c thats wired incorrectly!!
Old Aug 10, 2006 | 02:46 PM
eg6ajk's Avatar
Default Re: (QuickDxEk)
its possiblility, as well it could also be the acutal program on the ecu. programs such as Mugen do not have a/c enabled
Old Aug 10, 2006 | 03:30 PM
Sloshy's Avatar
Default Re: (eg6ajk)
it shouldnt matter, a/c system has it own wiring diagram it has nothing to do with the ecu. basicaly you have to start of with that. check a/c switch at the dash, then check you event have freon cuz clutch wont even turn on, if its low, if its not that try the relay under the hood and check if anything got cut (wires, ac lines and hoses) easy to happen when you do a swap..
mostly its the relay...
Old Aug 10, 2006 | 03:43 PM
pdiggitydogg's Avatar
interesting.....
Old Aug 11, 2006 | 01:05 PM
ekay. jay's Avatar
Default Re: (pdiggitydogg)
It was the wiring on the conv harness. Thx b18ccivics for the pin outs
Old Aug 11, 2006 | 01:15 PM
ek4_b16a's Avatar
Default Re: (ekay. jay)
NNnnnnNNnnnNIIiiiiiIIIIIIIIIIIiiiiiiiiiiiiiiiiiiii iiiiiCCCCCCCCCCCCCCCCCCCCCCccccceEEeeEEeeee!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 11, 2006 | 01:17 PM
ekay. jay's Avatar
Default Re: (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">it shouldnt matter, a/c system has it own wiring diagram it has nothing to do with the ecu. basicaly you have to start of with that. check a/c switch at the dash, then check you event have freon cuz clutch wont even turn on, if its low, if its not that try the relay under the hood and check if anything got cut (wires, ac lines and hoses) easy to happen when you do a swap..
mostly its the relay...</TD></TR></TABLE>
What do you mean the a/c has its own woring diagram? The wires for the a/c run straight to the ecu.....
Old Aug 11, 2006 | 03:08 PM
b18ccivics's Avatar
this guy needs to read my sig
if you dont know what you are talking about then dont post.
.1type.
Jul 3, 2008 05:00 PM
Coke in a Can
Mar 6, 2008 02:55 PM
d0hceg
Jun 14, 2007 11:39 AM
-Championship-
Sep 28, 2006 02:25 PM
SikofFalln
Dec 19, 2003 05:14 AM
