105 k too many miles for turbo?
Old Aug 2, 2006 | 08:33 AM
98blkgsrteg's Avatar
Default 105 k too many miles for turbo?
i have a 98 gs-r and i want to go turbo..the problem is i have 105k miles on the car/engine...is a turbo a bad idea for that many miles?
mrdeadman's Avatar
They let me pick
Default Re: 105 k too many miles for turbo? (98blkgsrteg)
no.
Old Aug 2, 2006 | 08:45 AM
Racermech's Avatar
Default Re: 105 k too many miles for turbo? (mrdeadman)
Get a compresion test to see how the motor looks. If the numbers are good then go for it.
Old Aug 2, 2006 | 08:55 AM
trick_db's Avatar
Default Re: 105 k too many miles for turbo? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">Get a compresion test to see how the motor looks. If the numbers are good then go for it.</TD></TR></TABLE>
x2.see if the compression is holding up, even though your car is at 105k, compression still might be good enough for boost
Old Aug 2, 2006 | 09:31 AM
scheistermeister's Avatar
yup, its not the number of miles, its the condition of the engine.
Old Aug 2, 2006 | 10:11 AM
Default Re: 105 k too many miles for turbo? (trick_db)
cool thanks alot
Old Aug 3, 2006 | 08:26 AM
VTECth1s's Avatar
go SC if your that worried and have doubts to go turbo because of high mileage, you'll have to do lotta maintenance work to even prep your car up for turbo..compression tests, leak down...etc then you would want to build the block sleeving, pistons etc... I suggest SC and do some minor maintenance work for prep. But all depends on what your goals are for hp and setup?
Old Aug 3, 2006 | 09:54 AM
Hbizzle's Avatar
Default Re: 105 k too many miles for turbo? (egg6vtak)
go for it!
Old Aug 4, 2006 | 09:38 PM
boostedblkef's Avatar
Default Re: 105 k too many miles for turbo? (blowndc2)
i sure hope not
Old Aug 4, 2006 | 09:58 PM
aznsins88's Avatar
like everyone says...do a compressoin test and if the numbers are good and close within eachother...TURBO THE BEAST!!!
Old Aug 5, 2006 | 06:15 AM
jared99's Avatar
Default Re: (aznsins88)
Turbo'd @120k. No problems. Well, engine-related anyway...
phish4709
Apr 15, 2007 07:02 PM
Chubz
Honda S2000
Nov 28, 2005 10:23 PM
SexyH22
Oct 2, 2003 05:59 PM
deeweezy
Mar 23, 2003 08:47 AM
See Are X
Sep 19, 2002 01:07 PM
