ok, temperature help please
Old Aug 1, 2006 | 10:17 PM
2fast4udude's Avatar
Default ok, temperature help please
ok, so here's the deal.
did the MPFI swap in march/april. shortly after the swap the temp guage quit working -- ok so i figured thermostat had gone sour. so tonight replaced the thermstat -- still no temp. the needle sits RIGHT at the top of the "C" and thats where it stays.
now i figure its got to either be the cluster (which i doubt), or the sending unit. Now, my question is where is the sending unit?
Anyone have any other ideas for me? I havent had a temp gauge since the MPFI and i'd love to get it back and operational. Anyone have any ideas??
Old Aug 1, 2006 | 10:24 PM
RCautoworks's Avatar
Default Re: ok, temperature help please (2fast4udude)
Green plug, if the gauge is spiking then its a bad ground.
Old Aug 1, 2006 | 10:49 PM
Default Re: ok, temperature help please (90blackcrx)
yeah its not spiking, its just not working..
but i recall looking at the motor today while hanging the thermostat and that plug was unplugged. i remember plugging it in, so it must have come unplugged. thanks!!
Old Aug 2, 2006 | 03:31 AM
7PSI CRX's Avatar
Hey!
That was my picture!
I'm glad it's still being used!
makes it sooooo easy, if you ask me.
Old Aug 2, 2006 | 04:05 AM
zccr-xsi's Avatar
have u tried a differant sending unit?
Old Aug 2, 2006 | 04:33 AM
marquisdee1018's Avatar
Mine is spiking. I replaced the red one in the picture. Do I need to replace the others also?
Old Aug 2, 2006 | 07:16 AM
marquis, if its spiking, read he said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Green plug, if the gauge is spiking then its a bad ground. </TD></TR></TABLE>
Old Aug 2, 2006 | 07:37 AM
Speed--Freak's Avatar
Hey, 7PSI CRX did or do you own a Teal Si with a JRSC?
Old Aug 2, 2006 | 09:07 AM
Default Re: (Speed--Freak)
lets not hijack this thread please.
ok, so thats not the issue -- it is plugged in, and its plugged in correctly -- i think. either way, it doesnt matter what way i plug it in, it still doesnt work. what is the correct way? black/yellow on top, or yellow on top?
Modified by 2fast4udude at 1:20 PM 8/2/2006
Old Aug 2, 2006 | 09:16 AM
crx_88_si's Avatar
Default Re: (2fast4udude)
Old Aug 2, 2006 | 09:22 AM
Default Re: (crx_88_si)
**** **** **** -- i'm colour blind guys. bare with me.
ok, so i'll go check that in a minute. the first picture, i saw the light blue i guess it is as green, and completely looked over the other sensor there.
sooo what is the blue sensor, and what ways are the wires supposed to be onit?
Old Aug 2, 2006 | 09:30 AM
crx_88_si's Avatar
blue = fan thermoswitch
green = guage cluster temp
red = engine temp sensor for the ecu
Old Aug 2, 2006 | 09:37 AM
ok, so what way should the 2 wires on the fan thermoswitch be? black/ywllow on top or bottom?
thanks guys.
Old Aug 2, 2006 | 09:40 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4udude &raquo;</TD></TR><TR><TD CLASS="quote">ok, so what way should the 2 wires on the fan thermoswitch be? black/ywllow on top or bottom?
thanks guys.</TD></TR></TABLE>
shouldnt matter, it just completes the circuit.
why are you messing w/ the rad fan thermo switch???
the sensor for the temp guage in the cluster is G R E E N (the middle one color blind boy!)
Old Aug 2, 2006 | 09:53 AM
lol like i said, my eyes didnt even seen the coolant sending unit on that 1st picture, all i saw was the fan thermoswitch and thought that was it... blonde moment. but yeah, all is well
i'll be testing the wiring harness and then the sending unit after i post this, and then going to buy the sending unit if thats the issue
Old Aug 2, 2006 | 11:19 AM
VeilSide_Mas's Avatar
great picture 90blackcrx.........
where can i buy the rad fan thermoswitch from? honda or autozone?
thanks
Old Aug 2, 2006 | 12:40 PM
Default Re: (VeilSide_Mas)
It works again. I went to the junkyard and pulled one from a car. Just wanted to make sure before I bought a new one. Installed it and no more spiking. Thanks for the help and the great picture.
Old Aug 3, 2006 | 12:01 AM
Default Re: (marquisdee1018)
ok, so heres my question NOW...
i figured the random check engine light was my o2 sensor, and i blamed the crappy gas mileage on that took. well yesterday i replaced the o2 and still, shitty mileage and random check engine. the ECU says nothing more than code 20, which is electric load, which is associated with the MPFI swap, i know that much.
my question, wil a faulty coolant temp. sender cause a loss of about 100-150 miles /tank and a random check engine that goes away immediatly?
Old Aug 3, 2006 | 03:40 AM
crx_88_si's Avatar
actually, is your ECU from the USA? because in Canada we dont have a Electric load detector in (they are normally in the fuse box).
which coolant temp sender? the ecu 1 will / can cause poor milage.
have you been resetting the ECU after checking the codes? (remove hazard fuse in engine bay box for 15 seconds or so).
Old Aug 3, 2006 | 07:47 AM
how do u guys actually remove the rad fan thermoswitch&gt;? i can't get any tools down there. do i have to remove the IM first ?
Old Aug 3, 2006 | 08:17 AM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeilSide_Mas &raquo;</TD></TR><TR><TD CLASS="quote">how do u guys actually remove the rad fan thermoswitch&gt;? i can't get any tools down there. do i have to remove the IM first ?</TD></TR></TABLE>
Have you tried getting to it from below?
Old Aug 3, 2006 | 08:45 AM
my question, wil a faulty coolant temp. sender cause a loss of about 100-150 miles /tank and a random check engine that goes away immediatly?</TD></TR></TABLE>
No, the coolant sending unit that sends the temp to the ecu would though.
Old Aug 3, 2006 | 09:01 AM
Default Re: (90blackcrx)
so its either bad ECU or the engine temp sensor to te ECU is bad? i've got to get this fixed today, these gas prices are killing me...
i know code 20 doesnt matter -- thats not an issue for me anyway. it doesnt give me a check engine light, just throws code 20 all the time. no big deal.
Old Aug 3, 2006 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4udude &raquo;</TD></TR><TR><TD CLASS="quote">so its either bad ECU or the engine temp sensor to te ECU is bad? i've got to get this fixed today, these gas prices are killing me...
i know code 20 doesnt matter -- thats not an issue for me anyway. it doesnt give me a check engine light, just throws code 20 all the time. no big deal. </TD></TR></TABLE>
No, if it was the engine temp sensor you would have that code. I was just stating the temp sending unit won't make your gas mileage worse.
Old Aug 3, 2006 | 08:23 PM
ell, i replaced both coolant temp sending units today, and the check engine is gone (so far) and the gas mileage is WAY up again. so it was one of thos 2 things
cpingor
Honda Civic (2001 - 2005)
Jun 7, 2011 11:24 PM
zippakilla
Feb 21, 2009 11:02 AM
Ryanman
Feb 10, 2008 11:51 AM
1991hb
Sep 27, 2007 06:10 PM
BigIslandBoi
Sep 26, 2003 03:48 PM
