1990 Honda Civic DX Smokes after replacing head.
Old Aug 1, 2006 | 05:10 PM
lexluther's Avatar
Default 1990 Honda Civic DX Smokes after replacing head.
I have a '90 civic, I bought is with a bad head, replaced the head and it runs great! It has 180 to 185 PSI on all cylinders. I checked the mileage by filling the tank, drove it and filled her back full and got 43 mpg. So the engine seems to be well, you almost cant hear it running, But, its using oil. When you rev it up 3 or 4 times about 3500 it puffs out the smoke. Blue smoke, Do you think its valve seals? or oil rings. I dont know if it used oil before. Other than this problem it seems to be a great little car. Thanks!
Old Aug 1, 2006 | 05:22 PM
crxb18ls's Avatar
was the head rebuilt? did you replace the head gasket? blue smoke? check your valve seals
Old Aug 1, 2006 | 05:32 PM
lexluther's Avatar
Default Re: 1990 Honda Civic DX Smokes after replacing head. (lexluther)
The head wasnt rebuilt, just pulled from a known good engine. we put new gaskets, including a new headgasket. The smoke is blue. I thought valve seals only caused smoking when you start one, and maybe when you shift gears. The car has 175,000 miles on it. But like I say, it runs like a top. If it werent for the smoking when you rev it up, and the fact it using oil, I wouldnt think it has a problem. I topped off the engine oil today, it took about half a quart, to 530 miles. thats excessive. COuld it still be valve seals?
Old Aug 1, 2006 | 05:43 PM
y-49's Avatar
yes it could be the valve seals. or bad rings
Old Aug 1, 2006 | 06:00 PM
lexluther's Avatar
I wondered about rings. But it runs too good I thought, gets over 40mpg. idles so quite you almost cant hear it.
Old Aug 1, 2006 | 06:18 PM
mahatma's Avatar
I hear ya
It's hard to get good head in KY.....
But seriously if you never drove the car before the head swap, it really could have been the rings all along....or a combination of both.
leakdown ftw
Old Aug 1, 2006 | 06:31 PM
lexluther's Avatar
The original problem was the car bumped another car, broke the radiator and the kid drove the car home, and blowed the head. WHne i got the car home, i did a compression check, 180, 0, 180, 180.....PSI. The number 2 cylinder had a bad valve, that looked like steam blew by it and cut a groove iin it.
Old Aug 1, 2006 | 06:54 PM
lexluther's Avatar
Your from Northern KY. I bought this little honda from Park hills, ky...basically Covington.
Logan L.
Engine Machining & Assembly
Jun 9, 2019 04:55 AM
lcsej1
Mar 13, 2009 02:40 PM
boostedhks
Sep 2, 2008 06:38 PM
90datech
May 13, 2008 07:10 AM
