Climate Control Removal Help!!
Old Aug 1, 2006 | 05:03 PM
Linh.'s Avatar
Default Climate Control Removal Help!!
I have a 92 honda civic and I've been trying to remove the climate control but it wont come out. I removed the two screws on the bottom front of the climate control, removed the one in center bottom, and removed the cable. I started pulling on it as hard as I could and it still wont come out. Is there anything Im missing?
Old Aug 1, 2006 | 05:15 PM
BlueIntegraBoy's Avatar
Default Re: Climate Control Removal Help!! (Linh.)
You are missing the clips for the harness plugs. They are a bitch to unclip, but there's an easier way.
If you look below the climate control, you'll see where the climate control subharness connects to the dash harness. Unplug that. Then there's a bolt that holds the bottom of the dash to a dash bracket behind the ashtray console. Remove it to allow the bottom of the dash to come foward enough for you to slide the subharness plug out. After this, slide the climate control out.
Old Aug 1, 2006 | 05:40 PM
Syndacate's Avatar
Default Re: Climate Control Removal Help!! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">You are missing the clips for the harness plugs. They are a bitch to unclip, but there's an easier way.
If you look below the climate control, you'll see where the climate control subharness connects to the dash harness. Unplug that. Then there's a bolt that holds the bottom of the dash to a dash bracket behind the ashtray console. Remove it to allow the bottom of the dash to come foward enough for you to slide the subharness plug out. After this, slide the climate control out.</TD></TR></TABLE>
Wish I knew that when I pulled mine....those clips are a BITCH....
Old Aug 1, 2006 | 05:42 PM
Default Re: Climate Control Removal Help!! (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Wish I knew that when I pulled mine....those clips are a BITCH....</TD></TR></TABLE>
Yeah, I know. When I did it the first time, I unclipped the bitch. Later on, I helped removed my friend's dash and found it simpler if you undid the subharness from the dash harness.
Old Aug 1, 2006 | 07:23 PM
Linh.'s Avatar
thanks
Old Aug 1, 2006 | 07:27 PM
E.Honda's Avatar
Seems there is a screw in the very back as well if memory serves me well.
Old Aug 1, 2006 | 07:38 PM
Default Re: Climate Control Removal Help!! (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">Seems there is a screw in the very back as well if memory serves me well.</TD></TR></TABLE>
Yeah, he got the 3rd screw.
Sinner
Jan 23, 2006 07:45 AM
ner0x
Jun 23, 2005 07:17 PM
va tech7
Jun 14, 2005 03:49 PM
Zoso1977
Nov 6, 2004 10:57 PM
Mr Boston
20
Oct 9, 2003 05:33 PM
