wats going on
Old Aug 1, 2006 | 02:23 PM
SVTPWD831's Avatar
Default wats going on
ok so...we did my buddies swap into his eg hatch its a gsr motor with p72obd1 ecu....my question is why isnt redlining all the way....it cuts out at lil over 7 grand...i been told it could be the KNOCK SENSOR or the BUTTERFLY VALVE...what do yu guys think.....?
Old Aug 1, 2006 | 10:29 PM
SVTPWD831's Avatar
bump...........i know someone has to know
Old Aug 1, 2006 | 10:30 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (SVTPWD831)
What do you mean by "cuts-out"? Any check engine lights? Any other symptoms?
Old Aug 1, 2006 | 10:31 PM
Turbo_y8's Avatar
i would think the fuel pump should be able to provide..., is the ecu chipped or anything that it has fuel cut at 7k?
vlc92189's Avatar
i thougt the gsr redline was 7200?
Old Aug 1, 2006 | 10:33 PM
SVTPWD831's Avatar
Default Re: (JDM_Ej)
it red lines at 7200 and check engine light is on
SVTPWD831's Avatar
Default Re: (Turbo_y8)
ecu is not chipped....
Old Aug 1, 2006 | 10:34 PM
SVTPWD831's Avatar
Default Re: (vlc92189)
um wat kind of GSR yu been drivin...?
Old Aug 1, 2006 | 10:39 PM
Turbo_y8's Avatar
well check what code the computer is throwing. Something is wrong and its telling you, just check it and maybe it will answer your problem instead of having random people guess at it over the interweb and the 100' of possiblities it could be...
Old Aug 1, 2006 | 10:46 PM
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">well check what code the computer is throwing. Something is wrong and its telling you, just check it and maybe it will answer your problem instead of having random people guess at it over the interweb and the 100' of possiblities it could be...</TD></TR></TABLE>
Couldnt have said it better myself. On Board Diagnostics, meaning you can diagnose your car just by asking it what is wrong... Why do people never use it????
Old Aug 1, 2006 | 10:47 PM
SVTPWD831's Avatar
well yea i was planning of pulling the code on friday when i was off....i was just trying to get some answers on wat could be going on.....!!!!!
Old Aug 2, 2006 | 12:35 AM
thahuhstunna's Avatar
yea, start by pulling the code and move on from there... update as soon as you figure out what code it is
Old Aug 2, 2006 | 11:20 AM
SVTPWD831's Avatar
alright i might around to doing it today.....
Old Aug 2, 2006 | 11:52 PM
SVTPWD831's Avatar
well i pulled the code.....its the map sensor.....the platic on the map sensor is broken will this case it to throw the engine light........if so does ne one have on laying around.....?
Old Aug 3, 2006 | 08:22 AM
Turbo_y8's Avatar
mine was also cracked(skunk2 proseries manifold install cracked it) but it still worked fine, but id replace it in your case since your actually throwing a code for it.
Old Aug 3, 2006 | 11:04 AM
SVTPWD831's Avatar
price range for a new one........its not the sensor thats broken its the clip that clips of the sensor thats broken ill post some pics up 2mmorrow
rotascircuit
Jul 31, 2007 03:14 PM
nek9
Dec 9, 2006 06:54 PM
Sl0wEK
Feb 12, 2005 03:18 PM
neEven
Jan 29, 2005 02:50 PM
hatchboy93
14
Apr 23, 2003 10:02 PM
