window problems, what could it be?
Old Aug 1, 2006 | 11:20 AM
HNP's Avatar
HNP
Default window problems, what could it be?
whats up ladies and gents...my 95 coupe has been bad to me lately, my passanger windown goes down and then 2 days later doesnt wanna work..i checked fuses and they seem to be fine and the motor seems to work..so anybody has any idead?? or anybody been thru this and fixed it?? thank you for readin
Old Aug 1, 2006 | 11:23 AM
g0tsilkk's Avatar
Default Re: window problems, what could it be? (HNP)
mine had a similiar problem, but mine was derailed. i ripped apart my door and put the window back on the railing and had to clean out some **** that caused it to derail. you might want to try that, but it does take some time. took me close to 3 hours because i had no idea what i was doing.
Old Aug 1, 2006 | 11:27 AM
jdmegciv92's Avatar
also use some silacone on the rubber channels that will let the window move freely in the channels
Old Aug 1, 2006 | 11:46 AM
kawickstrom's Avatar
Default Re: (jdmegciv92)
Don't use silacone in the window channels it will just dry up and your problem will begin anew. Instead you should use graphite powder. Anyway that has nothing to do with this because your window isn't binding. It is probably your window regulator or the window has come off the run.
Old Aug 1, 2006 | 11:53 AM
HNP's Avatar
HNP
Default Re: (kawickstrom)
the window is in its rail is not off, when i try to bring it down i should hear some sort of noise but i dont hear anything at all..so i really dont know what it could be
Old Aug 2, 2006 | 02:47 PM
HNP's Avatar
HNP
Default Re: (HNP)
i have no idea what this could be, but im gonna take it apart and see whats up, i will keep anybody interested updated
Old Aug 2, 2006 | 02:51 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: (HNP)
my friends window becomes derailed all the time...mostly when its cold or after it rained....not sure how to stop it from happening....
Old Aug 3, 2006 | 05:23 AM
HNP's Avatar
HNP
Default Re: (teamvirus)
is not derailed is just that it works when it feels like it..
Old Aug 4, 2006 | 06:02 AM
HNP's Avatar
HNP
Default Re: (HNP)
anybody else with this problem?
Old Aug 4, 2006 | 07:21 AM
d16vteceg's Avatar
Default Re: (HNP)
check the switch and the leads connected to the switch, make sure they aren't loose
Nealva
Oct 12, 2016 11:41 AM
GuitarPunk015
Dec 7, 2008 11:22 AM
jayare05
10
Feb 7, 2005 08:44 AM
asianspec
Jan 7, 2005 11:22 AM
Mycroft Holmes
Mar 14, 2002 07:42 PM
