Quick Q - OBDII vs OBDI - AUTO -> MANUAL swap
Old Aug 1, 2006 | 09:38 AM
stefanne3's Avatar
Default Quick Q - OBDII vs OBDI - AUTO -> MANUAL swap
hey - can you guys confirm this:
I'm having a manual transmission installed and my mechanic says i need to change the ECU to an ODBI. Is that true?
I didn't think the ECU needed changed, but rather reprogrammed. I thought ODBI was for cars up to '95. Anything past that has an ODBII.
Thanks much
Old Aug 1, 2006 | 11:15 AM
stefanne3's Avatar
Default Re: Quick Q - OBDII vs OBDI - AUTO -> MANUAL swap (stefanne3)
anyone got any thoughts??
Old Aug 1, 2006 | 11:20 AM
SilverDc2's Avatar
what year is your car? you shouldn't change the OBD,
Old Aug 1, 2006 | 11:22 AM
stefanne3's Avatar
Default Re: Quick Q - OBDII vs OBDI - AUTO -> MANUAL swap (SilverDc2)
it's a 99 LS
Old Aug 1, 2006 | 11:36 AM
91maroonGoon's Avatar
why would he even say that unless he wanted more money? all you would need to do MAYBE is change out your obd2 auto ecu for a 5spd. i swapped in 93 tranny into my 91 da, all i need to complete the swap is put in the 5spd cluster and a 5spd ecu, i run the auto ecu right now but it doesnt run to its fullest. hes just tryin to faux wit you
Old Aug 1, 2006 | 12:46 PM
SilverDc2's Avatar
Default Re: (91maroonGoon)
you have a 99 LS, its OBD II a or b?
your going to have to search for an ECU that fits, you can use the automatic one, but your going to have the check engine light on, its no biggie,
i did an auto to manual swap before..just FYI
Old Aug 1, 2006 | 12:55 PM
TexasluvsHondas's Avatar
Default Re: (SilverDc2)
I have a 94 Ls (obd 1) and I put a 2000 GSR tranny in. No CEL, same ECU, no problems.
Old Aug 1, 2006 | 06:17 PM
stefanne3's Avatar
Default Re: (TexasluvsHondas)
mine's a 99 LS and the mechanic said i would get more HP out of the engine if i use an ODBI - could anyone confirm this?
he also mentioned that upgrading the ODBII from an auto to a manual would be about $500 - so it could be that he's just trying to save some $$.
Could anyone confirm or deny that an ODBI would be the way to go on a auto to manual swap? Maybe also give some reasons for this.
Thanks much
Old Aug 2, 2006 | 06:58 AM
stefanne3's Avatar
i found some ODB2's for 96-99 for about $100 - so they're not really $500 as originally quoted.
I was told the ODB2's have some type of limiter around 6500 RPM's, that the ODB1's don't and that's why the ODB1 would be better suited for my application.
How true is that? Any thoughts?
Thanks
Old Aug 2, 2006 | 09:26 AM
stefanne3's Avatar
Has anyone downgraded from an ODB2 to an ODB1 for a good reason?
Why would one do that?
Old Aug 2, 2006 | 09:32 AM
SilverDc2's Avatar
people do go to OBDI because its easier to tune and few others thing, i dont think its worth the hassle. in my opinion.,
Old Aug 2, 2006 | 09:35 AM
unless you want to tune your car to a decent extent in the future its not worth switching over to obd1. if anything get an 5spd ecu for your car and swap it out and youll have no problem
Old Aug 3, 2006 | 01:37 PM
hybridej7's Avatar
obd-1= 92-95 honda/acura 1 O2 sensor
obd-2a= 96-98 honda/acura 2 O2 sensors
obd-2b= 99+ honda/acura
dont think you need to change ecu's just b/c your changing tranny's. think someones trying to get more $$$ from you
Old Aug 3, 2006 | 06:13 PM
stefanne3's Avatar
Old Aug 3, 2006 | 06:25 PM
trick_db's Avatar
yes people do that because it tend to run a lil better, and for other reason, and for your reason, no need too.
ferio-ichi3
27
Apr 16, 2013 12:48 PM
nolanator6
May 10, 2011 10:14 AM
tturbocivic0618
13
Apr 15, 2008 01:40 PM
5lugSlug
Jul 6, 2005 08:11 PM
alky350
Jan 18, 2004 09:38 PM
