Is this quite a lot of timing? (pic)
Old Aug 1, 2006 | 07:16 AM
A Blue Lude's Avatar
Default Is this quite a lot of timing? (pic)
I finally hooked a computer up to my hondata box to see what would happen, I was curious about my injector's duty cycle and how much breathing room I have...the digital dash on the computer is pretty cool, if distracting.
But I was kinda expecting the ignition timing values to be a bit lower (like twenty something) Does it seem high? It's a stock H22.
Screenshot from a high rpm/high load part of the drive.
Old Aug 1, 2006 | 07:47 PM
Default Re: Is this quite a lot of timing? (A Blue Lude)
One bump for an answer...
Old Aug 1, 2006 | 10:33 PM
mtber's Avatar
36 deg of timing at wide open throttle...
Yes that is too much timing at wide open throttle for most h22 applications.
Old Aug 2, 2006 | 03:45 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Is this quite a lot of timing? (mtber)
yeah thats alot of timing is your car tuned
Old Aug 2, 2006 | 05:57 AM
Dyno tuned for a different bolt-on H22.
May or may not be appropriate for my engine, either way...from my (very) limited amount of EFI knowledge I thought typical timing values for the high end of the RPM range were in the twenties, and that ignition timing was usually backed off as RPMs went up (this tune is pushing from the high twenties to the thirties as RPMs pass through 5000)
Old Aug 2, 2006 | 06:20 AM
flyrod's Avatar
That may not be the actual advance, depending on how you have things set up. The easy thing would be to pull out a timing light and compare it to the computer screen with the engine idling.
Old Aug 2, 2006 | 10:23 AM
XLR8 GS-R's Avatar
Default Re: Is this quite a lot of timing? (flyrod)
Hey, if theres no knockn keep walkn.. Advance will make the car dance
Old Aug 2, 2006 | 10:28 AM
R@mon's Avatar
Default Re: Is this quite a lot of timing? (XLR8 GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">Hey, if theres no knockn keep walkn.. Advance will make the car dance</TD></TR></TABLE>
LOL
95EG2
Jun 3, 2011 11:25 AM
RaceCarRyne
Feb 20, 2009 09:07 AM
RNbuilt
Engine Management and Tuning
Apr 9, 2008 09:17 PM
jetlude
May 6, 2007 06:11 PM
