i got a gsr motor and i need a new tranny...whats better b16 tranny or gsr tranny?
Old Aug 1, 2006 | 01:38 AM
EK SQUAD 425's Avatar
Default i got a gsr motor and i need a new tranny...whats better b16 tranny or gsr tranny?
whats better b16 tranny? because the gears are shorter so your faster? or the gsr tranny
Old Aug 1, 2006 | 02:55 AM
dailydriven's Avatar
Default Re: i got a gsr motor and i need a new tranny...whats better b16 tranny or gsr tranny? (EK SQUAD 425
depends...i have typer tranny with my gsr
Old Aug 1, 2006 | 03:54 AM
black_EM1's Avatar
Community Builder
Community Influencer
B16 tranny. Shortest gearing for B-Series.
http://www.allmotorhonda.com
Look under transmissions
Old Aug 1, 2006 | 04:00 AM
projectek's Avatar
I have a b16a(2) and the gears are SOOOO close together I am on rev limiter so fast. I'm not sure if that would be compounded by the increased power and torque of the C1 motor. It might give you more control on a road corse when shifting into and out of a turn. I am building a new block (B18c1 bored and sleeved to 2.0) and I'm pretty sure I'm going to go with a gsr tranny for that set up + it is going to be boosted.
Old Aug 1, 2006 | 05:22 AM
jays93eg6's Avatar
B16= short gears----
GSR= short 1st and 2nd, the other 3 are fair
I guess it all depends on what type of driving you will be doing.
Old Aug 1, 2006 | 05:30 AM
UNKNOWN_MEMBER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">B16= short gears----
I guess it all depends on what type of driving you will be doing.</TD></TR></TABLE> what are you smoking on. a gsr tranny going from 1st to 2nd is longggggg. 2nd to 3rd it decent then the rest are whatever. you probably haven't even drove/own a gsr tranny.
Old Aug 1, 2006 | 05:36 AM
Andres-eh2's Avatar
If the car will most likely see the highway most of the time go with gsr, if its more for track use go for b16. On the highway the b16 trannys rev so high just cruising. advantage is that u dont really need to downshift.
Old Aug 1, 2006 | 05:47 AM
jays93eg6's Avatar
heres my current 99' GSR swap in my EG
heres my car when I had the B16 in it.
So get your facts straight before you ask someone what they are smoking. I hate smartasses.
Modified by jays93eg6 at 6:58 AM 8/1/2006
Modified by jays93eg6 at 7:00 AM 8/1/2006
Modified by jays93eg6 at 7:02 AM 8/1/2006
Modified by jays93eg6 at 7:03 AM 8/1/2006
Modified by jays93eg6 at 7:04 AM 8/1/2006
Old Aug 1, 2006 | 06:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">what are you smoking on. a gsr tranny going from 1st to 2nd is longggggg. 2nd to 3rd it decent then the rest are whatever. you probably haven't even drove/own a gsr tranny
Modified by jays93eg6 at 7:04 AM 8/1/2006</TD></TR></TABLE> muahahahaahha that's funny, only facts i stated are about the gsr gears. look at the link above, gsr 1st and 2nd gear is just like an LS. are you trying to say LS gears are SHORT?! daym what a fool, supposebly you had a gsr and stating that the 1st and 2nd gears are short. ha. and to the OP, i'd say b16 for all motor gsr for turbo. only so you can have traction on 2nd gear.
Old Aug 1, 2006 | 06:59 AM
philosofy1's Avatar
B16 tranny!
Old Aug 1, 2006 | 07:12 AM
black_EM1's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> muahahahaahha that's funny, only facts i stated are about the gsr gears. look at the link above, gsr 1st and 2nd gear is just like an LS. are you trying to say LS gears are SHORT?! daym what a fool, supposebly you had a gsr and stating that the 1st and 2nd gears are short. ha. and to the OP, i'd say b16 for all motor gsr for turbo. only so you can have traction on 2nd gear.</TD></TR></TABLE>
Does anybody use this?
1st gear is the same, 2nd is slightly longer, and 3-5th are progressively longer than a B16 tranny
Old Aug 1, 2006 | 07:30 AM
what are you comparing? LS and GSR first and 2nd is the same.
Old Aug 1, 2006 | 08:13 AM
BlueIntegraBoy's Avatar
If you want, get a JDM 98 ITR tranny. It has B16 1-3 gears and GSR 4-5 gears. You'll accelerate fast, and be able to cruise. Then again, you have a 4.7 FD, you can still punch it.
Old Aug 1, 2006 | 09:06 AM
bokals's Avatar
^ hes got a point, go with the JDM ITR tranny
Old Aug 1, 2006 | 09:11 AM
fmrprojects's Avatar
im loving my 98 itr tranny. 4.7 final is the way to go
Old Aug 1, 2006 | 12:22 PM
Yep ITR tranny
Old Aug 1, 2006 | 01:20 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">If you want, get a JDM 98 ITR tranny. It has B16 1-3 gears and GSR 4-5 gears. You'll accelerate fast, and be able to cruise. Then again, you have a 4.7 FD, you can still punch it.</TD></TR></TABLE>
seems most suitable for performance/some hwy
EGLUVN
51
Aug 21, 2007 09:41 AM
smokerz212
Apr 25, 2006 02:04 AM
1994CivicGS-R
Sep 29, 2005 06:35 AM
locoSIR20
Feb 1, 2005 05:53 PM
92-EG6
30
Mar 14, 2004 06:18 AM
