oil coming out from behind distributor
Old Jul 31, 2006 | 08:06 PM
Paprika's Avatar
Default oil coming out from behind distributor
So I'm pretty sure there is oil leaking from behind my distributor...
How easy is this to fix?
I believe it's a simple gasket, should I get an OEM one or can I run to Autozone and pick one up?
Messing with the distributor can interfere with my ignition timing, so how can I do this most accuratly?
GOTO BOTTOM OF THREAD AND READ... CHANGES SUBJECTS.
Modified by Paprika at 12:15 PM 8/3/2006
Old Jul 31, 2006 | 08:19 PM
Paprika's Avatar
Default Re: oil coming out from behind distributor (Paprika)
Bah found it.
https://honda-tech.com/zerothread?id=1065831
Another redirect for future searchers!
Still wondering if one from Autozone will be okay... cause my local Honda dealer's parts department may not have it.
Old Jul 31, 2006 | 08:42 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">So I'm pretty sure there is oil leaking from behind my distributor...
Messing with the distributor can interfere with my ignition timing, so how can I do this most accuratly?</TD></TR></TABLE>
There is an O-ring that seals the distributor houshing and the head. Just pick one up from autozone. just scribe a line across the dist. housing and the head so you can re-align it when you re install it.
Old Jul 31, 2006 | 09:38 PM
Paprika's Avatar
Default Re: oil coming out from behind distributor (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">
There is an O-ring that seals the distributor houshing and the head. Just pick one up from autozone. just scribe a line across the dist. housing and the head so you can re-align it when you re install it. </TD></TR></TABLE>
Thanks!
Heres another quick question that I really need answered too...
Current OEM radiator has started leaking around the top tank.
I originally wanted to just seal it back up, but I was informed I'd better just replace it and save myself some headache....
Can I snactch up one of these ebay guys and be good to go for a few years?
http://cgi.ebay.com/ebaymotors...QrdZ1
Or should I seal my current one or what?
Old Aug 1, 2006 | 12:33 AM
jumai182's Avatar
Same thing happened to my radiator. Just replace it. Thats just a temp. solution IMO. I prefer an OEM just for the assurance when it comes to things like that. I got mine from a junkyard for $25 off a 99 EX.
Old Aug 1, 2006 | 01:06 AM
Paprika's Avatar
Default Re: oil coming out from behind distributor (jumai182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jumai182 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to my radiator. Just replace it. Thats just a temp. solution IMO. I prefer an OEM just for the assurance when it comes to things like that. I got mine from a junkyard for $25 off a 99 EX. </TD></TR></TABLE>
Oh so you snatched it up from a junkyard?
Well when you look at it like that you gotta do this type of comparison:
Used OEM w/ Miles on it vs. New OEM-spec Aftermarket
I think it's a toss-up as to which one will survive longer since we know the USED OEM may eventually go down just like the first one did. And what do we do if we need something more than a temporary solution? 2yrs considered temporary?
Old Aug 1, 2006 | 06:01 AM
jumai182's Avatar
Indeed you are right, it is a toss up. Oem replicas vs Used Oem. To me theres always something fishy about Ebay brand replicas. Most replicas average $60-80 and the one your looking at is $35 tops. I personally feel more comfortable gambling with an Oem product used and inspected in person. Btw my radiator gave out because my tstat needed replacement. Be sure to check yours before you replace your radiator.
Old Aug 1, 2006 | 06:05 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">Bah found it.
https://honda-tech.com/zerothread?id=1065831</TD></TR></TABLE>
Old Aug 1, 2006 | 06:37 AM
Paprika's Avatar
How did your thermostat affect your radiator?
and what can I do to "check" mines?
Old Aug 1, 2006 | 07:02 AM
philosofy1's Avatar
i don't know how a thermo would affect a radiator, but if your worried about yours then just replace it. they're pretty cheap. oh, as for the gasket i would go with oem. you can't go wrong!
Old Aug 1, 2006 | 07:12 AM
Paprika's Avatar
Well I'm not worried about the thermo just the radiator. and I'd love to upgrade to a performace one with metal tanks but I don't think it'll end up being a worthwhile investment for me.
Would you order an OEM thermo from online/dealership or grab one from Autozone/Advanced Auto/Napa?
Old Aug 1, 2006 | 07:35 AM
crxsrule's Avatar
Just change the o-ring
Old Aug 1, 2006 | 08:27 AM
Paprika's Avatar
Default Re: oil coming out from behind distributor (crxsrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsrule &raquo;</TD></TR><TR><TD CLASS="quote">Just change the o-ring</TD></TR></TABLE>
yeah we've already established that.
I went to the local Honda dealer and they didn't have the o-ring in stock. I haven't ordered it yet either. Autozone didn't have it either...
Old Aug 1, 2006 | 05:23 PM
jumai182's Avatar
Last comment since theres two topics in one. Thermostat allows for coolant to circulate. Mines got stuck. Never noticed because all my drives were local and short. Took a vacation trip oneday from Houston to San Antonio. On the way back my car was over heating, checked it and found my radiator cracked up around the cap area. Since your replacing the radiator just thought Id give a friendly suggestion as a precaution. http://www.ehow.com/how_7683_t....html
Old Aug 1, 2006 | 08:42 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jumai182 &raquo;</TD></TR><TR><TD CLASS="quote">Last comment since theres two topics in one. Thermostat allows for coolant to circulate. Mines got stuck. Never noticed because all my drives were local and short. Took a vacation trip oneday from Houston to San Antonio. On the way back my car was over heating, checked it and found my radiator cracked up around the cap area. Since your replacing the radiator just thought Id give a friendly suggestion as a precaution. http://www.ehow.com/how_7683_t....html</TD></TR></TABLE>
Thanks man, appreciated it!
I might just repalce it anyway... not sure yet, we'll see. I'm getting a plan together to order some stuff for the car.
Old Aug 1, 2006 | 08:45 PM
jumai182's Avatar
Np. Does your car misfire because of the incident with the oring?
Old Aug 1, 2006 | 10:06 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jumai182 &raquo;</TD></TR><TR><TD CLASS="quote">Np. Does your car misfire because of the incident with the oring?</TD></TR></TABLE>
No not at all. I think I'd notice a misfire tho if one came up... I had one once not too long ago after messin with the dizzy's rotor button or somethin... but I haven't been misfiring since.
Just bogging down; After car has been turned off and sat for a while the engine wants to bog down when i try to drive off. (Backs up fine tho) Usually happens at the rpm drop of the shift from 1st to 2nd.
Thats my main problem right now... the oil leak is just something I was wondering about the other day.
Old Aug 3, 2006 | 08:19 AM
Paprika's Avatar
To The TOP for an opinon on this radiator:
http://cgi.ebay.com/ebaymotors...wItem
Let me know, thanks.
Old Aug 3, 2006 | 06:48 PM
Paprika's Avatar
bump... let me know
Old Aug 4, 2006 | 08:19 AM
Paprika's Avatar
bump... can I get some type of advise?
minvi
Feb 28, 2011 09:25 PM
efking
Sep 28, 2006 12:44 PM
hatchbro
Oct 13, 2004 09:00 PM
porsche997dc2
Dec 22, 2003 08:49 PM
