Brake dust shields
Old Jul 31, 2006 | 04:47 PM
SiR99's Avatar
Default Brake dust shields
Just wondering if any of you guys have a picture of the itr brake dust shields. The one on the car has some weird bends and i think its creating noise, but i dont want to bend it untill i see how other itr shields are. Anyone happen to have a pic?
Old Jul 31, 2006 | 05:23 PM
Comp97GSR's Avatar
Default Re: Brake dust shields (SiR99)
Get rid of them...
Old Jul 31, 2006 | 05:32 PM
Chris F's Avatar
Default Re: Brake dust shields (Comp97GSR)
they bend away in one place. If they're not hitting the rotor they should be fine.
But yeah, ditch 'em
Old Jul 31, 2006 | 08:33 PM
SiR99's Avatar
Ya, im just going to take them off and see if it solves the problem. Wont alot of dust start traveling around though after I remove them?
Old Jul 31, 2006 | 09:08 PM
98 ITR's Avatar
No, not really ... well, not that you'll notice anyways.
Makes for much better cooling of the rotors though
Old Jul 31, 2006 | 09:23 PM
picos's Avatar
Default Re: (98 ITR)
and you could always replace them with diff pads that reduce the dust off
Old Jul 31, 2006 | 09:33 PM
330R's Avatar
Default Re: (picos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by picos &raquo;</TD></TR><TR><TD CLASS="quote">and you could always replace them with diff pads that reduce the dust off</TD></TR></TABLE>
Any recommendations? From what I've read around here, the OEM pads are the best balance between performance and dusting (or lack thereof).
Old Aug 1, 2006 | 03:16 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Get rid of them... </TD></TR></TABLE>
x2
Old Aug 1, 2006 | 04:26 AM
BudMan's Avatar
Default Re: (330R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R &raquo;</TD></TR><TR><TD CLASS="quote">
Any recommendations? From what I've read around here, the OEM pads are the best balance between performance and dusting (or lack thereof).</TD></TR></TABLE>
The real decision is to use one for daily driving & switch to another for performance. Other than autocross, the OEM's don't hold up for crap on a track.
Old Aug 1, 2006 | 11:54 AM
Arsenal's Avatar
Default Re: (BudMan)
Not sure if anyone else noticed this, but once I removed the dust shields the discs seemed to stay cooler, by quite a bit. (They would be alot cooler to touch when working on them after driving.
Old Aug 1, 2006 | 12:06 PM
88 rex's Avatar
Default Re: (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if anyone else noticed this, but once I removed the dust shields the discs seemed to stay cooler, by quite a bit. (They would be alot cooler to touch when working on them after driving.</TD></TR></TABLE>
I still burn my finger if I touch mine after a spirited drive.
Old Aug 1, 2006 | 12:29 PM
Arsenal's Avatar
Default Re: (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
I still burn my finger if I touch mine after a spirited drive. </TD></TR></TABLE>
Well that's stating the obvious, but in general they seem to run alot cooler.
Old Aug 1, 2006 | 01:45 PM
Opie's Avatar
That's the idea behind taking them off
Old Aug 1, 2006 | 05:16 PM
KayOs's Avatar
I would only suggest the above on an R that is driven on the track.
Old Aug 1, 2006 | 05:17 PM
88 rex's Avatar
Well that's stating the obvious, but in general they seem to run alot cooler.</TD></TR></TABLE>
Prove it
I've had mine off for awhile now and can't honestly say they seem to be any cooler on the street. In any case, there is no harm in removing them.
Old Aug 1, 2006 | 05:22 PM
KayOs's Avatar
In any case, there is no harm in removing them. </TD></TR></TABLE>
Agreed.
Old Aug 1, 2006 | 05:52 PM
tommymoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote"> In any case, there is no harm in removing them. </TD></TR></TABLE>
Melting ABS sensor wiring FTL!
While Honda engineers put them there for a reason, it seems that nobody has had a problem with them off, so you should be fine.
Old Aug 2, 2006 | 04:36 AM
88 rex's Avatar
Default Re: (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">
Huh? Has that happened to you? I don't have ABS in my car, but do you KNOW of someone who melted their abs wiring? They are dust shields, not heat shields. The only ABS I've seen has been on a SAAB and the sensor is attached to the pad, which is well past the dust shield.
b16a2EBP
Mar 3, 2006 07:09 PM
Mrfeee1
Oct 7, 2004 07:02 AM
apexinghonda
45
May 27, 2004 07:02 PM
Calavera
Sep 14, 2003 12:20 AM
Sima
May 19, 2003 10:17 AM
