Question about oil pan . . .
Old Jul 31, 2006 | 04:43 PM
thegeorge613's Avatar
Default Question about oil pan . . .
This popped into my mind last night. What's protecting the oil pan from rocks and bumps on the roads below? Sorry if this sounds stupid.
Old Jul 31, 2006 | 04:45 PM
petern101's Avatar
Default Re: Question about oil pan . . . (thegeorge613)
your brain/eyes.
and if you were to dent the oil pan, you are either too low or can't correctly avoid large objects.
you can buy some underbraces which will catch before it hits the oil pan
Old Jul 31, 2006 | 04:49 PM
Default Re: Question about oil pan . . . (petern101)
Ohh . . . becuase I was pulling out of a plaza a little too fast and I hear a thunk as I was going down those driveway ramps. You think that would cause any serious damage? My car is at stock height, BTW.
Old Jul 31, 2006 | 04:55 PM
petern101's Avatar
^you probably hit the crossmember or something.
i mean you aren't leaking any oil so no worries. you can have a slightly dented oil pan (although i would replace it) and be fine.
now there are some cases of extreme dents which causes the oil pickup to get knocked around and won't properly work which means problems for your engine.
just jack up the car and check it out
Old Jul 31, 2006 | 05:02 PM
Ah, alright. Thanks for the help, petern!
ballisticej1
13
Jun 14, 2009 08:50 AM
1992cxhatchB16A2
Oct 25, 2008 01:10 PM
RHDintegXsi
Jun 17, 2006 04:20 AM
speedy108
Jun 30, 2004 06:56 AM
