Tranny question
Old Jul 31, 2006 | 04:08 PM
importtuner07's Avatar
Default Tranny question
Ok i blew my tranny a couple of weeks ago just got another today my question is how much would it cost to have a shop put it in and what weight of gear oil should i use it is a 1994 Honda Civic Ex with a B16a swap Thanks in advance for any help
Old Jul 31, 2006 | 05:40 PM
modifyORdie's Avatar
Default Re: Tranny question (importtuner07)
i assume its a manual? just use 10-30 oil in the tranny or go royal purple...thats even better
Old Jul 31, 2006 | 05:53 PM
sauceja's Avatar
Default Re: Tranny question (modifyORdie)
As always I recommend Honda MTF. You can get it at the dealership. As far as paying someone to put it in?
Cost could be anywhere from 150.00 to 500.00 depending on where you go.
You could spend the 75.00 for a helm's and try it yourself. If you feel comfortable.
Old Jul 31, 2006 | 05:59 PM
fmrprojects's Avatar
Default Re: Tranny question (sauceja)
if you have the neccessary tools, then get a manual and do it yourself. but i always use honda MTF cant go wrong with it
Old Jul 31, 2006 | 06:46 PM
imadigitalgod's Avatar
Default Re: Tranny question (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">if you have the neccessary tools, then get a manual and do it yourself. but i always use honda MTF cant go wrong with it</TD></TR></TABLE>
^^^^^Definately.
I know you will need the Helms for the actual transmission change and maybe the helms for putting the fluid on but, i did a writeup a while ago on how to change/fill the transmision fluid:
https://honda-tech.com/zerothread?id=1687986
Old Jul 31, 2006 | 07:06 PM
sauceja's Avatar
Default Re: Tranny question (imadigitalgod)
Yeah that is a good write-up. Also I know some people use the vss to add, I put a different engine in my accord wagon and my pump broke (sat for a while unused) and my vss was buried under alot of stuff.
So I found out that by removing the vent cap I had a piece of hose that fit inside and I added my tranny fluid this way. Except when I fill mine, right after it starts coming out fill hole I try to put the plug back in while it is still leaking out a little. Kinda messy but I know there is not alot of extra fluid in there.
My .02
naTRON
May 13, 2006 02:01 PM
Reego.
Mar 30, 2006 09:56 PM
SHG_Beans
10
Jan 22, 2006 12:21 PM
jds62f
Nov 23, 2005 07:17 AM
Btothe3rdDegree
May 10, 2003 04:07 PM
