cel 22 VTEC pressure valve.....LIMP mode>???
Old Jul 31, 2006 | 03:06 PM
VRD^don's Avatar
Default cel 22 VTEC pressure valve.....LIMP mode>???
okay...the car has been setting for a while now..maybe almost for a month now..i then go and start it..it gives me a cel 22..which is VTEC pressure valve..this then throws the car into limp mode...cannot rev pass 5000 rpm..try resetting ecu..nothing..try adding more oil..nothing..have yet to clean the vtec soleniod..car is a 96 civic hatch with b16 boosted..street tunned on crome pro..
Old Jul 31, 2006 | 03:07 PM
VRD^don's Avatar
Default Re: cel 22 VTEC pressure valve.....LIMP mode>??? (k_motor)
idle oil pressure is roughly around 40-45psi..when cold..when warm idles oil pressure is around 20is-30 pis
Modified by k_motor at 6:53 PM 7/31/2006
Old Jul 31, 2006 | 03:12 PM
VRD^don's Avatar
just took the car out..revv'ed to 7000rpm..no vtec..
Old Jul 31, 2006 | 03:19 PM
fmrprojects's Avatar
clean the solenoid and change the oil.
Old Jul 31, 2006 | 03:22 PM
VRD^don's Avatar
Default Re: cel 22 VTEC pressure valve.....LIMP mode>??? (fmrprojects)
has fresh 10w40 in it..i'll be cleaning it once the car cools down..
Old Jul 31, 2006 | 05:48 PM
VRD^don's Avatar
cleaned it....nothing...switched solinoids..nothing...help guys!!
Old Jul 31, 2006 | 05:56 PM
THC07's Avatar
22 is vtec pressure switch, make sure it is all pluged it, the ROM has vtec right? you just stared it oneday and no vtec? probly dirty
THC07's Avatar
Default Re: cel 22 VTEC pressure valve.....LIMP mode>??? (THC1107)
oh and limp mode is more like 3k
Old Jul 31, 2006 | 06:18 PM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">22 is vtec pressure switch, make sure it is all pluged it, the ROM has vtec right? you just stared it oneday and no vtec? probly dirty</TD></TR></TABLE>
correct....let the car sat for good month..went to start it..boom..cel 22 ..cleaned the solinoid...all pluged in..rom has vtec....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">oh and limp mode is more like 3k</TD></TR></TABLE>
well its not in limp mode no more..first it wouldnt let me rev past 5k at all..its like a rev limit there..i then reset the ecu and it would rev past 5 k all the way to 8..
Old Jul 31, 2006 | 07:23 PM
THC07's Avatar
are you sure vtec was woeking before the car sat? what ecu is in the car? check for voltage at the selenoid.
Old Jul 31, 2006 | 07:58 PM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure vtec was woeking before the car sat? what ecu is in the car? check for voltage at the selenoid.</TD></TR></TABLE>
positive the vtec was wokring before i let the car sat..ecu is p28 with crome pro..have yet to check voltage at teh solenoid
RinzEG6
Oct 14, 2014 03:34 AM
5280dc2
Apr 6, 2008 07:53 AM
mister2racer
Jun 26, 2005 07:13 PM
GSR_ITM
Apr 16, 2005 09:37 PM
