cel 22 VTEC pressure valve.....LIMP mode>???
okay...the car has been setting for a while now..maybe almost for a month now..i then go and start it..it gives me a cel 22..which is VTEC pressure valve..this then throws the car into limp mode...cannot rev pass 5000 rpm..try resetting ecu..nothing..try adding more oil..nothing..have yet to clean the vtec soleniod..car is a 96 civic hatch with b16 boosted..street tunned on crome pro..
Re: cel 22 VTEC pressure valve.....LIMP mode>??? (k_motor)
idle oil pressure is roughly around 40-45psi..when cold..when warm idles oil pressure is around 20is-30 pis
Modified by k_motor at 6:53 PM 7/31/2006
22 is vtec pressure switch, make sure it is all pluged it, the ROM has vtec right? you just stared it oneday and no vtec? probly dirty
Re: cel 22 VTEC pressure valve.....LIMP mode>??? (THC1107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 »</TD></TR><TR><TD CLASS="quote">22 is vtec pressure switch, make sure it is all pluged it, the ROM has vtec right? you just stared it oneday and no vtec? probly dirty</TD></TR></TABLE>
correct....let the car sat for good month..went to start it..boom..cel 22 ..cleaned the solinoid...all pluged in..rom has vtec....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 »</TD></TR><TR><TD CLASS="quote">oh and limp mode is more like 3k</TD></TR></TABLE>
well its not in limp mode no more..first it wouldnt let me rev past 5k at all..its like a rev limit there..i then reset the ecu and it would rev past 5 k all the way to 8..
are you sure vtec was woeking before the car sat? what ecu is in the car? check for voltage at the selenoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 »</TD></TR><TR><TD CLASS="quote">are you sure vtec was woeking before the car sat? what ecu is in the car? check for voltage at the selenoid.</TD></TR></TABLE>
positive the vtec was wokring before i let the car sat..ecu is p28 with crome pro..have yet to check voltage at teh solenoid
mister2racer
06-26-2005 07:13 PM
